Question about Iomega NAS P405u (32372) 80 GB Hard Drive Array
How to Install OS on Iomega 450R?
I have tried various ways to install Server 2003 on this device. It doesn't seem to see CD/DVD drives via sata. I don't have an external one. When I install the OS on a HD then put the drive in the NAS it will not read the OS. PXE seems to work, but it states the drivers for the NICs is not present and cannot install (how it is displaying all this from PXE if it cannot install it that way is beyond me.) Any thoughts on what else I can try?
  • Timothy Detwiler
    Timothy Detwiler Dec 12, 2013
    I gave up. I assume the board is now deffective and got my money back.
I have a GF615M-P33V2 - how can I get Windows Server 2003 drivers and software? Also, IDE CD/DVD only work intermittently. Is there any way I can connect a CD, DVD and a floppy. I've already an IDE HD...
Hi, the download site is here:
http://www.msi.com/product/mb/GF615M-P33.html#/?div=Driver&os=All
But there is no drivers for windows 2003.
The 32 bit driver for windows xp will sometimes work
if it is a 32 bit system.
You can buy an external floppy drive and a cd/dvd drive to
connect the usb.
But the mainboard has a connector for the floppy drive.
Try to install the chipset drivers first and unzip the file before installation.
Consider to buy a mainboard compatible with windows server 2003
I will recomend a ASUS mainboard.
Sep 17, 2011 | MSI GF615M-P31 AM3 NVIDIA GeForce 6150SE &...
Unable to boot to anything external.
Save yourself some trouble. Pull a CD/DVD drive out of another computer or just buy one. They are very cheap. Connect the CD/DVD drive to the server and install the OS as usual.
If you are lucky WS2008 will already have a compatible SCSI/RAID driver. Otherwise, you will need to press F6 and install the driver from the floppy.
If this helps please vote for my solution.
Sep 07, 2009 | Dell PowerEdge 2600 Server
Problem loading an OS onto a Dell XPS One 2010
YOU NEED THE BIOS UPDATE FOR THAT ,,GET IT FROM A ANOTHER CPU ,,BOOTABLE DOWNLOAD,,PUT IT ON THE DELL ,,THEN XP,,CHECK THE DELL WEBSITE
May 15, 2009 | Computers & Internet
Problem with sata HDD probably?
check the bios settings first. if you can see your sata hdd and dvd rom drive then you can install it with no problem. or else try to replace the cables of the hdd if the hdd is not showing up in the bios.
also check that the hdd is set to master drive and dvd also set to master as they are on different connections.
Apr 21, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
Installing Windows Server 2003 on a preinstalled Vista OS
The reason it is showing "no hard disk" is because you have a SATA hard drive, and there is no SATA support on the WS2003 software, so it doesn't even "see" the drive when trying to install.
What you can do is download SATA drivers for your hard drive to your machine. Once downloaded and/or extracted, restart the installation but choose F6 to load "SCSI or 3rd party drivers", then point to the downloaded drivers.
Your installation will then load the SATA drivers, thereby recognizing the hard drive and you'll be able to successfully install Windows.
Hope this helps - remember to rate :)
Oct 06, 2008 | Microsoft Windows Server Standard 2003 for...
Intel DG31PR Motherboard
Did you get an error message during install of the (system with the SATA 160GB drive)? Make sure the 160GB drive is shown in the bios. Than go to the title, Boot in the bios & make sure the SATA 160GB is listed in the boot order. (Preferred 3rd. boot device)
Please go to the SATA drive's manufactures site & download either their bootable floppy or CD setup software. (It’s free)! Use their software to setup the FAT & cluster size on the drive. You can even set other features that neither the bios or windows can do. Format the 160GB drive with the software as well. The manufacture's software does a better job than windows. If the 160GB drive is a SATA 2.0 leave the jumper on the drive alone. The Desktop Board supports four Serial ATA channels (3.0 GB/s) via ICH7, connecting one device per channel.
Again, please run the manufactures setup software for your SATA 160GB drive. (Disconnect any other drives that may be in the system until windows is installed).
Intel's web site here: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Good luck ameyaniks!
If I missed something, just let me know.
Mike
Sep 11, 2008 | Intel DG31PR Motherboard
Installing Iomega CD-RW
OS 10.3 is greater then os9.1, perhaps there is a 10.3 driver available somewhere, Ill keep an eye out for one.
Jan 27, 2008 | Iomega (32885) CD-RW Burner
CDROM and with a bootable CD is not been detected
Same solution as posted before if you need to boot from a DVD: take a Dell laptop CD/DVD combo drive, remove the screws and all and exchange the PowerVault CD drive unit with it. Same internal connector. Can't remember what model I stuck in, but I had to keep the front panel of the drive since it was slightly different, I probably could have glued it, but.... That's a server machine no one is ever going to see but me! :)
That also gave me a CD-Burner which is a decent addition in case you need to quickly burn a CD/make a backup/boot disk (like a "ultimate Windows CD" boot to fix anything that could go wrong).
Nov 29, 2007 | Dell PowerEdge 2600 Server
Cannot install any Windows OS system
My first course of action would be to isolate the problem. So what i would do is un hook one of the 500 gb Sata drives. Then try to install on one. Once you get it up and running hook the second one up and let windows find it. Also another note of thumb is make sure you have not over exceeded your ram slot capabilities. Find the techical manual on the manufactures web site. Each ram slot has a max amount and speed. If you exceed these it can cause windows programs to halt. I do think that if you isolate down to one sata drive install your os then add your second Sata you should be good to go. If you are still having problems feel free to contact me. TechWizard
Sep 21, 2007 | Tyan Tomcat K8E Motherboard
Iomega NAS P405u (32372) 80 GB Hard Drive Array Logo
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
