Question about Hobart AM14-253 Free-standing Dishwasher
Need a motor and pump for AM 11 where can i find one?
  • 2,113 Answers
In my city (London Canada) we have many many used restaurant equipment and new restaurant equipment supplies. I don't know what country/state/province/city etc etc to be able to direct you.
Posted on Nov 28, 2013
Pump Leak
there is a cheap gasket/ o-ring that needs to be replaced
May 31, 2013 | Pentair Dynamo 1.5 Hp Pump & Motor Dynii...
Super 11 pump clogged impeller how to fix
Remove the 6 bolts holding the motor mounting plate to the pump housing. Back the motor assembly out. Remove the diffuser and you'll see the impeller. Using picks and wire run through all of the impellers vanes to clear out the debris.
Mar 19, 2013 | Hayward 3/4hp Super Pump Inground Pool...
I had a hayward 11/2 hp 2 sp...I put a AO 2 hp 1 sp on my ing. pool and how it just hums and shuts off. I checked everything out and primed it before I tried to start the pump. Can anyone help
Turn off the power and remove the end cap at the center back end of the motor. The end of the motor shaft is then exposed and you can use a 9/16" open end wrench to verify that the motor shaft is turning freely.
If it offers resistance the pump needs to be opened and checked to find out why. If it does move freely, take it to a pool store or motor shop to test it. Rarely, a motor gets out of the factory DOA.
Jan 19, 2013 | Pool & Spa
My in-ground pool pump...Sta-rite 11/2 hp...leaks at the outlet fitting. Changed fitting twice, using teflon tape as recommended...still leaks.
I don't recommend Teflon tape as it places outward pressure on the pump and can cause the pump body to crack. and if that happens the pump body will need to be replaced. I use black RTV silicone. smooshing it into the threads of both fittings and hand tightening the fitting.. then the glue the pipe as normal
REMEMBER to prime the pump after any pump repair !!
Teflon tape works well on metal pump like well and irrigation, they are a high pressure pump and are generally cast iron tanks.
Jay the pool pump motor repair guy longwood Florida 32750
Mar 14, 2012 | Sta Rite Pool & Spa
Hello I'm trying to dismantle my hayward pump, but can't seem to able to remove the turbine... without forcing it too much....any tricks?
IT TURNS OFF TO THE LEFT, YOU NEED A 7/16 OR A 11 mm WRENCH TO HOLD THE ROTOR AT THE BACK OF THE MOTOR.. LOOK FOR THE NOTCH IN THE SHAFT UNDER THE SYNTRIFICAL SWITCH ASSEMBLY , BE CAREFUL NOT TO BREAK ANYTHING ON THE BACK OF THE MOTOR. REPLACE THE SEAL ! THERE IS A GUY SELLING SHAFT SEAL HAYWARD SUPER PUMP MOTOR REPAIR KIT & how to
ON EBAY .. HEY YOU .. PRIME THAT PUMP AFTYER ANY PUMP REPAIR !! THERE NOT SELF PRIMING UNTIL THERE INITIALLY PRIMED IN FIRST PLACE !!! AKA PUT WATER IN THE PUMP !.. IF I WAS OF HELP CLICK ON THAT (YES) BUTTON ON THE BOTTOM LEFT OF THE PAGE.. REMEMBER A CLEAN POOL IS A SAFER POOL .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA ..
Jun 11, 2011 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
I have an 11 year old Jacuzzi Magnum Force 1227 pool pump model 15UMFS. I want to replace it, but don't know how many horsepower it is. Can you tell me?
Probably 1.5 HP but if you can read any of the nameplate data on the motor it would be helpful to confirm. A better approach might be to size the new pump to the volume of water in the pool.
If all you are going to replace is the pumps motor then can you provide at least the amp ratings off the motor? Those should help verify what your old unit's horsepower really is.
John
Apr 14, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
Maytag A108 pump belt slips and doesn't pump, is there a belt tensioner that engages when the water needs to be pumped out?
The pump belt is designed to be loose to a certain degree, however the drive and pump belt should be replaced every 11 years to maintain optimum performance. The instructions on the belt packaging shows how to properly set the tension. The motor mount may also need some attention at this stage of life. Remove the 2 philips screws at the bottom of the front panel and disengage from the top panel by pulling outward at the bottom of the front panel. Tilt washer slightly backwards far enough to reach under and pull off the drive and pump belt. Make sure that the motor rolls freely in the motor mount assembly. Lubricate with 3 in 1 oil if necessary, (or other light wt. oil). Install new belts as per package instructions. Test spin before replacing front panel.
Aug 16, 2009 | Maytag Washing Machines
Code f 11 and f 20
its not called f-20 its caled f-02 Long Drain ----- means -------
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.-----------
to resolve the code ---------- Press PAUSE/CANCEL twice to clear the display. Press PAUSE/CANCEL twice to clear the display. globul1a.gif Check the drain hose and make sure it is not plugged or kinked. globul1a.gif Check the electrical connections at the pump and make sure the pump is running. globul1a.gif Check the drain pump filter for foreign objects. globul1a.gif If the above does not correct the problem, replace the pump.
code f-11 means --------
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.----------------- to resolve the problem ------------- Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
Mar 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wipers
Fuse #11 is the one to pull.
30A Runs Front Washer Pump Relay, Wiper Run/Park
Relay, Wiper Hi/LO Relay, Windshield Wiper
Motor, Rear Washer Pump Relay
Nov 21, 2008 | 2000 Ford Expedition
Hobart AM14-253 Free-standing Dishwasher Logo
97 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
