Question about Kenmore 60721 Refrigerator
Emerson compact CR519B not cooling
Hear a clicking every so ofter compressor not running
3 Suggested Answers
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
  • 1218 Answers
SOURCE: Refrigerator fan running not cooling
Good day,
That is the compressor not running. Could be a bad compressor, or one of it's starting components.
You can remove the start components from the compressor, by removing the cover, and pulling them off the compressor pins.
Any decent sized appliance parts house will test the components, usually made up of the overload protector, start relay, and on some models a start/run capacitor.
If any parts check bad, replace them, if they all check O.K. then you will need the services of a trained service tech.
Posted on Feb 20, 2010
Emerson mini model cr501e frig and freezer both quit working what should I check No
check to see if the compressor in the back is running. This is not easy to hear has they are really quiet. If it running and its not cooling then it is low on refrigerant, if the compressor is not running then it could be a bad compressor, or the thermostat is not working or adjusted right. Thermostat is likely located inside the frig.
Sep 19, 2016 | Emerson Refrigerators
Tip
My Refrigerator quit working.
1. is light on in side when you open the door. If not check breakers or fuses.<br /> 2. Can you hear the compressor running. If not do you hear any clicking sounds.<br /> 3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.<br /> 4. Wait one hour.<br /> 5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.<br /> 6. If it goes back to clicking, call a service man.
on Feb 21, 2011 | Refrigerators
Emerson mini Fridge will not cool. Electronics?
Sounds like the compressor starting componets or a capacitor is bad.
Jan 03, 2018 | Emerson Refrigerators
Fridge not getting cool and i do not hear it running but has clicking sound
replace the ptc overload/relay mounted on the side of the compressor in the rear area of the unit,it helps start and operate the unit,thats where the clicking sound is coming from
Oct 16, 2012 | Magic Chef MCBR360HW 3.6 cu. ft. Compact...
MCBR240s Magic Chef Fridge does not cool. Compressor gets very hot when plugged in, but no cooling, it also makes clicking noises
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 10, 2011 | Magic Chef MCBR440 Compact Refrigerator
Magic chef compact refrigerater stopped cooling compreser is warm to touch and is makeing clicking noise every few minutes
heatman101
May 09, 2011 | Magic Chef MCBR445B2 (4.4 cu. ft.) Compact...
Hiya,i have a hotpoint fridge freezer ffa91 and the fridge is no longer getting cold.The compressor seems is hot but cant hear the normal noises coming from the fridge.The digital display shows an arrow...
4. Wait one hour.
try this
Mar 12, 2011 | Hotpoint Refrigerators
Nothing running in refrigerator. Unplugged unit for 2 hours then pllugged back in. unit ran for about 30 seconds then stopped again
4. Wait one hour.
try this
Mar 10, 2011 | Amana Refrigerators
Frezzer runs but the compresser does not comes on
4. Wait one hour.
let me know if this helps.
Mar 04, 2011 | Frigidaire Freezers
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
4. Wait one hour.
also are the coils clean?
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
Kenmore 60721 Refrigerator Logo
1,349 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
