Question about Ryobi 18-inch Electric Chainsaw Chain Saws
On a ryobi petrol chainsaw does the prer pump into carb or does it pull petrol through
  • Ryobi Master
  • 2,239 Answers
The purge bulb always pulls fuel from the carb and dumps back to the tank.
Posted on Nov 21, 2013
  • 2692 Answers
SOURCE: need parts for ryobi pcn3335
http://www.ryobitools.com/parts
Posted on Jan 18, 2009
dontbother10
  • 2220 Answers
SOURCE: Looking for spare parts for an 20 inch petrol
Try here:
Homelite/Ryobi.com
http://www.gardnerinc.com/recons/disclaimer-lg.php
Lou
Posted on Sep 05, 2009
  • 4088 Answers
SOURCE: petrol leaking when turned up side down
Upside down is not a usual sawing position--only upright, or turned to the left or right side is recommended. If you need to undercut something, keep the saw upright and cut with top side of the chain/bar.This can lead to kick-back if the tip comes free of the log/branch, so you need to control the saw carefully. That's also why there is a chain brake on all newer saws. The leaking may be occurring where the fuel lines pass through the wall of the fuel tank. Hope this helps!
Posted on May 04, 2010
  • 10865 Answers
SOURCE: user manual
Hello. Go to this link http://search-manual-online.com/ryobi-chain-saw-manual.html
Joe
Posted on May 05, 2010
  • 1514 Answers
SOURCE: my Ryobi petrol RCS 3540c
Check that the chain is on the right way around. The cutting edge of the teeth on the chain, at the bottom of the bar should face towards you and away from you on the top. It's most likely that the chain is facing the wrong way. If you don't know how to fit a chain look at the video on http://www.ehow.co.uk/video_4419336_replace-chainsaw-chain.htm
If that's not the problem then the chain is blunt and needs to be sharpened badly. You can sharpen it, with a special file which can be got from chainsaw dealers, or take it to a garden tool hire centre and have it sharpened professionally. It has to be sharpened professionally from time to time anyway to keep it cutting straight so if it's that blunt I'd recommend you get done professionally now.
The smoke if it's coming from the chain is caused by overheating from trying to cut with the chain which is too blunt or turned the wrong way. If the smoke is coming from the engine check your fuel. You should have petrol mixed with 2 stroke oil. The saw manual will give the ratio of 2 stroke oil to petrol. If you use too much oil or if it's not 2 stroke it will cause smoke from the engine. Also if you use cheap oil it can cause smoke. It's best to use good quality oil like husqvarna or stihl 2 stroke. These also protect the saw better than the cheap brands you get at car service stations which are really only meant for boats which are water cooled.
Posted on Jan 20, 2011
Testimonial: "Thankyou, I'll check that. It's only about a year old and hardly used so possibly not blunt but chain problems."
Why does primer bulb suck bubble when pumped on my ryobi 46cc chainsaw
you have a hole in your gasline they dont cost much but finding it is the thing hope this helps
Aug 15, 2014 | Ryobi Chain Saw. 20 in. 46 cc Gas Chain...
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
No fuel (2 stroke) getting into priming bulb of Ryobi petrol chainsaw 18"
Change the fuel filter in the tank, if this does not help there is dirt in the carb, remove the carb, under the pump diaphram is a filter screen, replce this.
Apr 07, 2011 | Ryobi Garden
Which oil and how much to ue in cs1800 ryobi
every you top up with petrol top up with chain oil as this will give chains a longer life,
use any chainsaw oil you can get it from places like b&q.
Jun 17, 2009 | Ryobi Garden
14" Ryobi petrol chainsaw will only run for 10 seconds
You are on the right track. Keep priming which indicates the fuel mixture is too lean to run. In other words the fuel line is partially clogged up. A drop of water on the gas tank would cause this problem. The fuel is fed on the suction basis. So clean up the fuel tank, (disassembly the carburator) reservoir, needle, float, offrice and fuel filter. A can of carburator cleaner (spray one) is a big help.
Jun 04, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi pcn 4040 chain saw
I have the same model chainsaw with the same fault. The brake is not releasing when the brake handle is pulled right back. I can only run mine if the brake handle is pulled back to the main handle with a tyrap - defeats the object of the auto-brake completely. Design fault I reckon.
Sep 28, 2008 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
80 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
