Question about Hyundai Electronics E320D 32 in. LCD Television
Power light turns green but no picture or sound
When I turn the power on the TV, the light turns green and the light remains on, but the display never comes on, and there is no sound.
  • 1 more comment
  • AMedtia Nov 30, 2007
    Have exactly the same problem! what are we to do?
    my mobile: 07966155161
    "power light turns green but no picture or sound problem, and then switches itself off to red light!!"
  • SlickTinkz Mar 05, 2009
    I turn on my Hyundai E320D LCD TV and the light turns green like usual, but it makes a sizzling sound from the back and doesn't turn on... I turned it off and disconnected it and it smelled like something was burning... Any idea's what it could be and what I can do to fix it? Thanx
  • theritzie Apr 17, 2009
    Yeah I've got the same thing too, it happened once before and I sent it back as it was still in warranty but now its happened again and the warranty has expired. Shoddy workmanship if you ask me. Guess I have to take it to a Tv repair shop
Tv does not turn on
If green light flashes more than 8 times, it could be as simple as repairing or replacing the power supply. Unplug the TV ,remove the back. Look for bulged or leaking capacitors on the power supply. Do it yourselfer? only if you have soldering skills, or purchase replacement board. remember, used boards are just as old as your failed board, buy new or rebuilt, Good Luck
Feb 17, 2014 | LG Televison & Video
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
I have no picture or audio on my TV. The green
It sure sounds like the mainpower supply problem, the power supply may be trying to turn itself off because it detects short circuits.
Nov 01, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
No picture, no sound, green light flicker ongoing
The power supply in the Tv has failed and should be looked at by a qualified technician.
Sep 09, 2009 | Samsung Televison & Video
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hyundai Electronics E320D 32 in. LCD Television Logo
54 people viewed this question
Top Hyundai Electronics Televison & Video Experts
Tom Chichester
Are you a Hyundai Electronics Televison and Video Expert? Answer questions, earn points and help others
