Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
It wont turn on
After travelling from Colombia to Germany my simpledrive 500gb wont turn on. it worked perfectrly before my trip
    Top Expert:
  • SimpleTech Master
  • 12,962 Answers
Could be a problem with the AC cycles. European gear is usually 50 cycles and so is their electricity. Or it could be a voltage issue.
When you travel abroad with your gear you must make sure that the juice available where ever you go is compatible with your equipment lest you risk equipment damage/failure.
Posted on Nov 23, 2013
4 Suggested Answers
  • 979 Answers
SOURCE: My computer doesn't recognize the SimpleDrive...
Good day sir, hi, It looks to me that your simple drive is giving up on you. Im assuming that the correct device driver is loaded properly.
There are two major part that you may try to test, the interface board and the hard drive. Hopefully the interface board is the cuplrit.
Have you tried in on another PC, you can also remove the hard drive, and place it on another computer. If done properly, you can get your files stored in it. then buy an aftermarket USB hard drive enclosure (without the hard drive). to replace the simpletech enclosure.
Posted on Nov 20, 2009
bronk50
  • 27725 Answers
SOURCE: My Hitachi Simpledrive 500gb won't be seen by my pc & the led is flashing, could you please let me know what I can do?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Jul 09, 2012
SOURCE: My Hitachi SimpleDrive 500GB says it's full but it's only at 400GB. I can't figure out the problem.
are you trying to install software into it
Posted on Aug 08, 2012
My SimpleTech SimpleDrive Pininfarina 500GB... stopped working
open the hard disk casing remove the drive check it on some other casing
May 06, 2014 | SimpleTech SimpleDrive Pininfarina 500GB...
What watt power supply do I need for 500GB SimpleDrive USB 2.0 External Hard Drive (designed by Pininfarina)?
The power adapter for the SimpleDrive is 12V, 2A, with center pin positive. I hope this helps.
Feb 17, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
My SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive suddenly disconnects a Reconects again....
You may have a power supply that is defective or is failing. Try another power supply, 12V, 2A, center pin positive.
Jan 24, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Hello jajogeglez,
You may need to use another USB device, be it another flash drive to narrow down if it's just your Simpledrive that's causing this.
You can also update the USB devices under your Device Manger using the CD driver for your motherboard.
Hope this helps.
Nov 20, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
500Gb SimpleTech Ext Drive No Power
Hello.
It sounds like you might have a problem with the power supply.
I have seen MANY external hard drives with failing power supplies. Take it to the store you purchased it from for a check up, it should still be under warrantee if its only 3 months old.
Good Luck!
Jun 17, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
49 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
