Question about Saws
Snapped blade stud/screw on my skilsaw - Saws
Snapped blade stud/screw on my skilsaw 5166. Borrowed this off of my dad on the promise of, if you can fix it you can have it because he didn't know why the blades wouldn't attach. On closer inspection, the bolt holding the bald has snapped in the bit that turns it...any ideas how to fix this or can I not?
  • 2,113 Answers
You can drill the center of the bolt. Use the smallest bit you have to center as best as you can and progressively use a larger drill bit. remember that the bolt turns clockwise to remove or loosen. Since bolt removal tools likely are designed for the opposite direction you may have to use a screwdriver to try to turn it out. Hit the screwdriver with a hammer a few times into the hole you drilled until it can catch and turn. It likely is not rusted in place and will likely turn easily. Order a new bolt for that make and model from an area small appliance repair place.
Posted on Nov 21, 2013
  • 313 Answers
SOURCE: Removal of Blade
turn the blade screw same direction as the blade rotation if you want to remove it.
Posted on Sep 19, 2008
efs_perpends
  • 1996 Answers
SOURCE: cant get blade off
I don't know which model you're using, but normally there's an arbor lock button on the motor side of the blade somewhere that allows you to lock that whole middle housing down so it won't turn. Look underneath the motor and see if you can't find some kind of lock botton or lever. That will make it easy to loosen the nut and tighten the blade down correctly.
Otherwise you're going to have to improvise some way to lock it in place enough to break that nut loose.
Reply with a model # and I can try to find a parts schematic to check for you...
Posted on Apr 10, 2009
SOURCE: How do I change the blade?
use a hard board to hold blade tight
rem: unplug power cord... thats how i've had to do it
at times
Posted on May 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Skilsaw motor runs blade won't turn
It sounds like you bought a lemon possibly. I am thinking that the gears are bad. What you can do is remove the blade and unplug the saw. locate where the screws holding the bearing cover are and remove them to get to the gear and check it. Let me know if you need more help
Posted on Jun 27, 2009
  • 15 Answers
SOURCE: How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Posted on Jun 08, 2010
How to change blade on skilsaw 5380
on a circular saw
pull the power lead from the plug
using a screw driver , place the blade between the teeth and turn until the screw driver is jammed under the plate
use a ring spanner and undo the nut that holds the blade on
pull the blade out and fit the new blade with the direction arrow in the right direction
replace the plate and the bolt do the bolt up tight
rotation will tighten it up
some blades have a hole in the blade in which to insert the screw driver to hold the blade , or a lock lever behind the cover to hold the armature shaft while changing the blade
Dec 21, 2016 | Saws
Skilsaw 5380 blade installation problem.
Don't know exactly, but on amazon you can find user manual. here Skil Circular Saw Model 5350 Owner Manual Operating Guide Paperback 1988 . Hope this was helpful. cheers skilsaw-5380-blade-installation-problem-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Jan 20, 2013 | Skilsaw 5380 Circular Saws
Jun 07, 2010 | Skil Saws
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
How to replace a guard spring on a model 367 skilsaw
take blade off and under blade there is a giude around shaft area around housing where sping goes i hope this was helpful
Aug 28, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Where is blade lock for my Skilsaw 5150 located
look for the button on the right side of the handle. Other models require you to put a phillips head screwdriver into a hole in the blade to hold it against the body of the saw.
Jul 13, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Jun 27, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Removal of Blade
Sep 18, 2008 | Blade Saws
SNAPPED STUD TO THE WATERPUMP
is it copper or plastic tubing? Just replace that part.
Sep 20, 2007 | Intel Motherboard
Saws Logo
134 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
