Question about Toshiba Camileo X100 High Definition Camcorder
Camileo x100 wont charge
Usually charged with just a usb into my computer or with my adapter into the wall but not the lights come on to show that it is charging then just turn off
  • 5 Answers
SOURCE: Battery wont charge
is either the battery is bad or the charging IC is bad.
Posted on Dec 15, 2007
SOURCE: Toshiba A100 Power problems
here are few laptop troubleshooting guide to troubeshoot ur laptop. it has one post about power problem of laptop.
I hope this laptop troubleshooting help to solve ur problem. or chekc ur laptop with another working battry or try to start laptop to without battery. and chekc ur power cable for charging is working or not
Posted on May 06, 2008
  • 2567 Answers
SOURCE: My computer wont turn on but the low battery keeps
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 07, 2010
Testimonial: "Thank you im going to try this right now!!!"
miket756
  • 2702 Answers
SOURCE: Charging continues to flash even
have you checked that the charger is charging the camera battery up?????
it could also be a dud camera battery,,if one cell is duff the hole battery wont charge up to its full volts so the charger works its **** off trying to charge up a dud battery till one day the charger just burns out as well?
Posted on Nov 27, 2010
ginko
  • 19396 Answers
SOURCE: I own a Toshiba Camileo
Hi.
The light stays yellow because you are using the USB charger. The USB charger is suitable for occasional use. You need to purchase a replacement charger. Here one of the forums from users with your same problem.
The Amperage of the USB charger is less than the DC charger. If the battery does not hold charge anymore, then the battery may also need replacing.
Here the charger and battery:
US:
CAMILEO Charger.
TOSHIBA CAMILEO H30 Battery
UK
Camileo H30 Charger
PX1657E-1BRS Battery
Regards.
Ginko
Posted on Mar 29, 2011
Spy pen not working
If you have a Spy Pen, sometimes it just appears to be either stuck with the light on, or dead and won't turn on. We wrote this report to show you some of the tricks we found to getting your it to work again.
1. Perform A Hard Reset
The majority of the time, just inserting the end of a paper clip in the opening below the status light on the back, and performing a hard reset, will get your Spy Pen working. Just bend a small paper clip end out, and insert straight into the opening. When you meet resistance, push lightly, and you can feel the reset button depressed.
Make sure it goes straight in, and not at an angle, or you could damage some of the components inside. Let go and try to turn it on.
2. Rule Out The USB Cable
If you are using a USB cable to either connect the Spy Pen to your computer, or to the 110V wall charger adapter, one day the cable will fail. If you use the USB cable because you can't connect the pen directly to the computer, try just plugging it directly into the computer.
Don't use a USB hub, as sometimes there is not enough power for the it; just connect it directly to the computers USB port. On some computers, use the USB port on the back, as front USB ports are sometimes weaker.
3. Rule Out The 110V Wall Charger
Just like the USB cable, the 110V wall charger adapter will also fail at some point; so if it does not seem to take a charge, try charging it for 3 hours in the computers USB port. If the status light is on while its charging, its getting electricity to charge the battery.
4. Put The Spy Pen Back In Video Mode
Several Spy Pens have switches to go to photo mode, or voice activation mode. If you move the switch to change modes, and you do not move it back to video mode, the computer will say it is not recognized. Try moving the switch back to the original position.
5. Erase & Reformat The Spy Pen
If the Spy Pen shows up as a removable drive on your PC, just right click on the icon and let go on "Format." Then check the "Quick Format" button, then hit OK. The drive will be erased, and reformatted. This usually takes care of any pens that make it this far.
Feb 13, 2014 | Computers & Internet
Camileo h10
The charging lamp burning, does not give any guaranty about the quality of the battery. It only shows power is applied to the battery.
Your battery although it still can have a little charge, can be on its end of life. The only way to be sure the battery is still fine is to measure its voltage with a multi meter. If you do so, the voltage should be above the voltage printed on the battery. The nominal voltage on the battery is the voltage it will have when working in he camera. I think you have to buy a new battery. And please when you have a new battery, charge it several times a year, even when you don't use it between the holidays.
Jan 30, 2014 | Cameras
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
My Toshiba Camileo x100 won't charge?
Try with normal USB cable &take out laptop USB port .actually I misplaced my ac adapter try for many solutions at I found this
Jul 02, 2012 | Toshiba Camileo X100 High Definition...
Nokia coolpix p100 wont charge
In General. Nikon Coolpix cameras TURN ON when you change them. This means when you plug in USB with a computer the camera turns on and the computer sees it.
If you turn the camera ON. And the Battery indicator shows "FULL CHARGE" you may NOT be able to charge it.
To eliminate variables. Do not charge with the computer until you charge with the adapter (wall charger). When the wall charger works then try the computer.
Look at page 145 in your manual for Computer charging.
Make sure your date and time are set in the camera.
Make sure it NEEDS a charge.
Aug 13, 2017 | Nikon COOLPIX P100 Digital Camera
I have connected my nanomax ipod to the computer and it is not charging.how should i charge it?
Good morning, afternoon, evening or night; whatever time you are viewing this solution post. Thank you for choosing FixYa to solve your problem. So you have connected your Nanomax iPod to the computer and it's not charging like it's supposed to, and you want to know how you should charge it properly? There are two ways you can charge the battery - charging via your Dock Connector to USB Cable, or the Apple USB Power Adapter (which is sold separately). Here are the step by step instructions to charging your and Nanomax.
Using the Dock Connector to USB Cable
  1. Using your Dock Connector to USB Cable, plug the dock connector end to your iPod and plug the USB end to your computer. Make sure the computer you are using has a USB 2.0 port (check your computer's technical specifications to see if it's USB 2.0 certified). Most USB ports on the keyboards of laptops do not provide enough power to perform charging activities. If you have a Docking Station, plug the docking connector into the station and placed the iPod in the station as well.
  2. Make sure your computer is fully awake and not asleep (meaning in sleep mode).
  3. A fully charged battery takes 3 hours to complete. An 80% charged battery takes an hour and 30 minutes. The battery is charging when it shows the charging icon (a battery not fully shaded in green, with a lightning bolt).The battery is done charging when the "fully charged" icon shows (a green-shaded battery with a 2-prong plug showing).
  4. When you are done, disconnect the cable from your computer.
Using the Apple USB Power Adapter
  1. Connect the Alternating Current (AC) Plug Adapter with the power adapter (if connected already, skip this step).
  2. Using your Dock Connector to USB Cable, connect the dock connector end to your iPod and the USB end to the power adapter.
  3. Plug the power adapter into a polarized wall outlet or surge protector outlet.
I think you connected everything correctly, but the USB port on your computer did not have enough power to charge your battery. If that's the case, you will have to find a computer that has a USB 2.0 port on it (like a desktop PC or MAC, or a car adapter charging device) and connect to it, or use the USB Power Adapter (sold seperately). I think this pretty much answers your question. I hope this benefits you the best way possible. Once again, thank you for choosing Fixya as your one-stop solution spot for your problems. Have a good day, evening or night; whatever time you are viewing this, and visit us again the next you need assistance troubleshooting.
Apr 27, 2011 | Audio Players & Recorders
Wont charge from a wall socket
the AC to DC adapter might be out of order, check it up
Apr 09, 2010 | Philips SA5245/02 Digital Media Player
Tried to do a restore on my 40 gig Ipod A1059. It started the restore and then it went to a screen showing a wall adapter. I always charge via USB and don't have a wall adapter. Help!?!
Sep 22, 2009 | Apple iPod MP3 Player
Not working.
I have no charge in my philips hdd82 player. Usually I just plug it into my computer via usb and a screen shows up on the player showing its connected and it charges. Usually it comes up as an MTP device on the computer so I can add mp3s as well. Now for no reason at all, when I plug it in, it doesn't charge and the computer doesn't recognize it. The screen shows an outlet when I plug it in so I know the cord works. It just won't let me do anything. When I press the on button with the cord unplugged, I can't do anything either b/c no charge. HELP. plz.
Nov 16, 2007 | Philips HDD082 MP3 Player
Toshiba Camileo X100 High Definition Camcorder Logo
83 people viewed this question
Top Toshiba Video Cameras Experts
Voros101
Are you a Toshiba Video Camera Expert? Answer questions, earn points and help others
