Question about Coby TF-TV1514 15 in. LCD TV
Tv is on channel 33 its screen is black and i cant change channel or get on the menu
Its screen is black and i cant change channel or get on the menu
SDTV CONVERTER BOX BLACK SCREEN MENU WONT COME UP
Maybe pressing the SETUP button the remote will get results.
Nov 28, 2013 | Magnavox TB110MW9
Cant get the sports channels on new starview 5 box
Press menu,while on installation press 1570,changes to nagravision,press ok,changes to the provider i.d.,scroll right to telewest 5a01.change codes using handset.
telewest codes 5a01 updated 12/10/09
00 CF 53 0C 33 79 61 71 85
01 52 5E 8D 45 FC 75 F6 4A
Oct 30, 2009 | StarTech.com StarView SV211K 2-port KVM...
Cant change ''favourite'' channels or get ''menu''
Make sure the batteries are fresh in the remote control ( I am assuming you are using a remote control to access the on screen display) If you have a universal remote and replaced the batteries you most likely will have to enter the code for the specific TV that you have.
Jun 14, 2009 | Televison & Video
BLACK BOX PROBLEMS: Insignia TV/DVD combo
The black box is caused by the Closed Caption option of the tv. Go into the menu and turn it off.
Jul 18, 2008 | Insignia IS-LCDTV32 32 in. Television
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Black box on screen
go into menu find
cc settings and
change setting to off
(make note of the one thats
causing the problem)
Dec 02, 2007 | Sansui DTV2760 27" TV
How to get rid of a black screen on my tv. sound is ok
If you mean that you get a black box, with a little of the picture visible around the edges, then your closed captions are on and set to TEXT. This puts a black box on the screen about 10 seconds after changing the channel. Go into the menu and turn off the closed captions and the picture will be back to normal.
Jul 07, 2007 | JVC AV-27530 27" TV
Cannot set Cable Default Channel
I believe you are getting mixed up between channels and programs. Normally program 00 is used for VHS as it has slightly different parameters for colour and brightness. If the TV has about 39 or more programs which can be programmed in from the on screen menu, try using program 20 for the video and 30 for the cable. For this to work you must do the on screen frequency scanning from channels 22 to 69 (UK) and select VCR, CATV, VHF, UHF, etc. I have used program 00 and 20 for two VHS recorders, working on channel 33 and 35 for example, but you must tune them to 33 and 35 on the `Tune' screwdriver hole by the aerial input sockets of the recorders. I expect if your cable unit plugs into your aerial socket of the TV that it has an adjustment for what channel it is on. The TV on screen menu may be different in some countries, so it would help if I knew where you are.
Oct 21, 2006 | RCA F32632SB 32" TV
Coby TF-TV1514 15 in. LCD TV Logo
14 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
