Question about Panasonic DVD-LA95 Portable DVD Player
Panasonic dvd-la95 only charges for 10 minutes?
Unit will only charge for 10 minutes thwen goes back to solid red power light is there any way to reset the unit or make it charge for more than 10 minutes?
Flashing red light on Morphy Richards 732000 Supervac
If it is supposed to go green then the battery is not being fully charged. Unit is under warranty and now is the time to have matter addressed.
Aug 20, 2015 | Vacuums
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
Laptop dies when unplugged
Panasonic Toughbook PC Laptops usually have
very reliable battery pack. When your unit is plugged-in
but the Power is OFF, you should see an LED light as follows:
RED FLASHING: Means the battery needs replacement.
Orange/Yellow Solid: Means battery is charging.
Solid Green: Means battery is fully charged.
NO Light AT ALL: Means that Battery Pack is missing.
There is also a battery calibration utility on all Panasonic
Toughbook PC's manufactured since 2004. This is a factory
installed software and is only present in factory units.
This software may also be downloaded as a driver from the
Panasonic Toughbook website as follows:
http://pc-dl.panasonic.co.jp/dl/
Check also in the bottom right hand corner under
Windows for the battery Icon. This will indicate if
the battery is charging, present or not present,
and under Windows 7+ will indicate if the battery
needs to be replaced or not.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
May 01, 2013 | Panasonic Toughbook Computers & Internet
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Stopped working while running.
flashing power light ??
thought you had to turn them off to charge it.
Jun 02, 2009 | Panasonic DVD-LA95 Portable DVD Player
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Panasonic LA95 Portable DVD
any flashing red powerlight ?? (assuming theres any charge left)
if the powerlight flashes quickly then the units kaput ( bin it)
slow flashing means the microswitch may be stuck (the one that turns off the screen when you close the lid.
you may have to be sneaky at a dealer and ask to plug in to a new mains unit ( most new panasonics still use the same power supply voltage and ampage. if it works then run away quickly and go buy a universal power supply, if it doesnt , well your in the right place tobuy a new one ??
Mar 11, 2009 | Panasonic DVD-LA95 Portable DVD Player
Flashing red light Panasonic portable DVD-LA95
check the microswith near the hinge . its generally located on near the back right corner of the player , on the control surface. it looks like a very small white plastic button or pip. sometimes these stick down and look like part of the player casing, when they actually are a switch. it needs to be raised , so when the lid is closed it pushes the pip down and turns the screen off. Try prising it gently free with a pin or needle. this happened tome and i was on the verge of binning it. when i looked at the manual and it says power light flashing slowly means screen turned off.
if the light is flashing very quickly then im afraid its knackerred and just not worth repairing.
if this is helpful to you then just drop me a line at choonzy@googlemail.com
good luck
choonzy
Jan 03, 2009 | Panasonic DVD-LA95 Portable DVD Player
DVD player just shuts off when using
As you say - - if it does not happen all the time, you have the worst problem ever.
AN INTERMITTENT FAULT - Horrid
You are likely to be correct, and have a loose connection / poor solder joint / dry joint within the unit.
Time and patience could find this fault - as long as you have a soldering iron, and a good avo..
Oct 10, 2007 | Panasonic DVD-LA95 Portable DVD Player
Panasonic LA95
You bought it on Ebay ! ! Why did the seller move it on...
I suspect that the decoder is getting 'hot' - same principle as the processor on your PC.
If you are able - I would suggest opeing the unit up (so that the main board is visible) but still able to power up.
Obtain a hair dryer that has a 'cool' blow on it. Start your unit up, while blowing with cool air - this will identify if this is thermal related...
Sep 07, 2006 | Panasonic DVD-LA95 Portable DVD Player
Panasonic DVD-LA95 Portable DVD Player Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
