Question about Qualstar Computers & Internet
Code 35-1706-1103 I can't clear this error message. Handler Fault Not Clear Code 35-1706-1103 Enter to Continue
    Top Expert:
  • Qualstar Master
  • 6,702 Answers
In what configuration are you using this drive(s) Can you tell me more about the drive unit, like type number, installed drives and so in?
Posted on Nov 27, 2013
User manual
Because the TLS 8433 can be assembled out of different drives (LTO /Ultrium and so on) and can be used with different operating systems, I only could get some links to qualstar.
Perhaps when looking here, toy can find your way to the correct configuration and error.
3 links
Nov 20, 2013 | Qualstar TLS 8433 (TLS-8433) Ultrium Tape...
Code 35-1706-1103 in Qualstar TSL 8433
Sorry, just saw this one.
You are addling the tape robot with what software? can you tell?
Nov 20, 2013 | Qualstar TLS 4222 AIT Tape Drive
System error 000 and 003
The E000 and 003, are the code for temperature fault in fixing unit.
There are two possibilities...
First:
enter service mode *(add.function) 2 8 *, by keys left/right go to CLEAR and OK, select ERR and OK.Turn off and on.
If these helps, you can continue to copy.
Second:
if the error clear not working you need to replace fixing heater.
Hope that helps!
Feb 11, 2011 | Canon iR 2016i Black and White Copier
1999 BMW 323i Message reads "Code Wait" after I
Your going to need to reset the codes in order to clear this issue.
Please remove the main red lead going into your BMW battery, wait a few seconds, then reinstall the lead. The error code will now go away. If you continue to have problems, please return.
Jan 19, 2011 | BMW 3-SERIES CONVERTIBLE
Error message H 4
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Jul 08, 2008 | Xerox Office Equipment & Supplies
H4 message call service
May 27, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Printer
Give this a try, 9 times out of 10 it fixes the H4 problem.
> Support & Drivers > WorkCentre XD100 Digital Copier - Laser Printer Support > How To Clear an H4 Code Solution: Perform a Fault Reset 14 bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
Mar 10, 2008 | Sharp AR-M160 Laser Printer
Xerox Workcentre Pro 215
This should resolve that fault code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
Jan 24, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Computers & Internet Logo
112 people viewed this question
Top Qualstar Computers & Internet Experts
David Payne
David Payne
Are you a Qualstar Computer and Internet Expert? Answer questions, earn points and help others
