Question about Uhu SAUNDERS CERVICAL HOMETRAC DELUXE
Number to repair dept. - Uhu SAUNDERS CERVICAL HOMETRAC DELUXE
Repair manuelCrosman Recruit Multi-Pump .177 caliber...
Hi, I call crosman all the time.If it is more then a year old you can't send it back to them. But they have a great service dept. The phone number for crosman service dept is 1-800-724-7486. Ask if you can speak to cameron in customer service dept. Tell him Joe Bagli Sr from florida told you to talk to him. Hope this helps you out. Joseph.
Jan 27, 2013 | Crosman Recruit Multi-Pump .177 caliber...
WE HAVE A SHARP ER-A610 CASH REGISTER WE WOULD LIKE TO CHANGE THE ITEM LABEL FOR EACH DEPARTMENT KEY BUT DON'T KNOW THE JOB # AND PROCEEDURE FOR DOING IT I DON'T HAVE ALL THE PAGES OF THE MANU
Sharp uses a 3-digit ASCII code for each character. The ER-A610 manual has a table of the codes, but if you've lost that part of the book, you can find ascii tables online, like this one:
http://www.ascii.cl/
Note that many of these show 2-digit codes; add a leading zero to those, so A is 065, B is 066, etc.
the 00 key on your ER-A610 has a special purpose here - it is used to enter each character's code, so to spell FOOD you'd enter:
070 00
079 00
079 00
068 00
where each of those double-zeroes is the double-zero key, not just two zeroes.
You need to know the number of each department you need to change. If you're not sure what order they're numbered in (It's completely customizable, so don't count on them being in order, unless you're sure.), print out your current department programming:
(In PGM1 or PGM2 mode)
1100 @/FOR CA/AT
will print out all the depts. CA/AT is the Cash key at the bottom-right corner of the keyboard. It stands for CAsh / Amount Tendered, which isn't exactly obvious, so some folks relabel it.
Note that on the tape you printed, the name is printed below the dept. number.
Now we're ready to start. In PGM2 mode, enter:
2114 . @/FOR (Is the decimal point after the 2114 visible here?)
[dept. number] @/FOR [character codes] SBTL
(etc. until done)
CA/AT
For [dept. number], enter the number on the keypad, not by touching the actual dept. key.
[character codes] is the sequence of 3-digit codes and 00 key presses, like the FOOD example above.
If the departments you're changing are sequential, life is a little easier. When you finish Department 6 (for example) by touching the SBTL key, it will automatically count up to 7. You can do a series of depts. by entering the first of them as above, then after using the SBTL key, go straight into the character codes for the next in line. Continue this way for as many are in series. You can jump ahead or back at any time by with [dept. no.] @/FOR and keep going from there.
SBTL in all the lines above, means the key that normally shows your subtotal including tax. It might be labeled #/SBTL. The MDSE SBTL key won't do the trick.
If you use PLU's in you register, their names are programed exactly the same, except that instead of starting with 2114, you use 2214. Simple, no?
Jan 11, 2013 | Computers & Internet
Dropped Flash
call olympus spares dept. You need the exact part number, which can sometimes be hard to get, sometimes they will fax the diagram so you can id the part. The spares dept tel # is hard to find. The links on olympus website will not get you there and the consumer hotline will not give the spares dept #. They now try to keep consumers from fixing stuff themselves and a lot of spares they no longer will sell to you. They used to be one of the best and very helpful. I managed to get a spare battery cover after a lot of hassle a while back, but they said they would not supply most parts for these newer flashes.
May 24, 2010 | Olympus FL-40 TTL Flash
Where can i get repair parts for a hifonics brutus bx1605d mosfets number for power supplier output driver numbers
THE NUMBER FOR MAXXONICS IS 847-540-7700, BUT I BELIEVE YOU WILL FIND THAT THERE IS NO PARTS DEPT. THERE. IF YOU CAN READ THE NUMBERS ON THE DEVICES IN QUESTION, I MAY HAVE THEM IN STOCK. I AM LISTED IN THE REPAIR DIRECTORY OF THIS SITE AND CAN BE REACHED AT PROFSRVCS@AOL.COM LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Oct 29, 2009 | Hifonics Brutus BX 1605D Car Audio...
I have a Garmin Nuvi 350 NA It functions fine, but the speaker is crakling at normal volume. Can it be repaired at a reasonable price vs. purchase of a new unit?
If you contact garmin.com, there is a toll free number to call that will get you to a warranty claims dept. or repair dept. Many times, if you let them know of the problem, they can either fix it free or very cheap. I had 2 warranty claims on the same unit and they fixed my speaker. I just checked and got the support number. Call them and see if they can help. 1-800-800-1020 and ask for support. Hope this helps! Good Luck!!!
Aug 01, 2009 | Garmin GPS
Car radio in safe mode
pull radio get id number and call dealer parts dept with number and they should be able to help you
Dec 18, 2008 | 2002 Audi A6
Casio TE4500F Programming Departments & linking to PLU's
Hi.
To link a PLU to a dept:
Turn key to program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number and press the 'PLU' button (eg 1 PLU for the first plu)
Now type the dept number to link to. Use two digits eg 01
Now press 00 (double zero)
CASH
SUBTOTAL
To set a dept name:
Turn key to program.
2 SUBTOTAL
Type dept no in 2 digits eg 01
Type 05
SUBTOTAL
Type new dept name using character sheet
00 (double zero)
CASH
SUBTOTAL
That should do it.
Let me know if you have problems.
Mark
Dec 18, 2008 | Casio Parts Cash Register PC Desktop
REPLACEMENT FILTERS FOR THE POWERFORCE 6 BAGLESS VACUM.IS THERE A BISSELL STORE IN THE DETROIT MICHIGAN AREA I CAN FIND BISSELL BELTS FILTERS ETC.
Here are Bissel's numbers, they can tell you who to contact.
Service Center Dept. Phone Number:
(800) 457-1509
Service Center Dept. Fax Number:
(800) 517-9535
Hours:
M-F 8:00 a.m. - 5:00 p.m. ET
Aug 10, 2008 | Bissell Vacuums
Where to find the upper tank for model 3760C
Here is the Bissell number, they can tell you who to contact near you.
(800) 457-1509
(800) 517-9535
Hours:
Aug 09, 2008 | Bissell Vacuums
Uhu SAUNDERS CERVICAL HOMETRAC DELUXE Logo
Top Uhu Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you an Uhu Luggage and Travel Expert? Answer questions, earn points and help others
