Question about GE Profile Spectra JGB920 Gas Kitchen Range
I have a GE JGB920 gas stove. It has the back burners light but the front burners don't. Any tips on repairing? BFGSAT
jsrock516
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
SOURCE: stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Posted on Feb 08, 2008
SOURCE: cleaning and care for my GE Profile stovetop
The one thing I don't suggest is using the Ceramabryte product the dealer left with us. It leaves a greasy film. When I get ready to clean my black GE Profile, I pull off the controls to wash separately. Then I lift off the grates, take a single-edge razor blade to scrape anything stuck on (it doesn't scratch), then I use baking soda and scrub and scrub with lots of paper towels. Then I start cleaning off the baking soda with lots and lots more paper towels. There is still a film, but at least it's not greasy. At this point I grab some more dry paper towels, pour on a 3' puddle of rubbing alcohol and wipe it all over the stove top and front. You may have to do this twice. Then, if I don't turn on the hood light's brightest setting, it really doesn't look too bad. I have to do this at least once a week, as I have never had a stove that got so dirty so fast and was such a pain to clean.
FYI, I would never buy another of these stoves. Besides the cleaning issue, there is the fact of having to replace the igniter (glow plug?) twice in the first four years. My old, bottom-of-the line Magic Chef went 25 years with the first replacement not coming until it was about 15 years old. Also, the broiler is unimpressive and steaks, etc., just sort of steam. Can't get a really good crust going. It's a slide-in and the top is very narrow, front to back, because of the slanted control panel on the front, and so you really can't put two large pots or pans on one side. Let's see....oh yes, I ordered the unglazed grates for safety reasons and it came with the procelain glaze. Those were replaced free of charge, though I had to go pick them up. Then the first set of unglazed grates began to rust about six months into use, so had to be replaced (again, no charge at least). Recently I noticed that the inside walls of the oven, where the racks slide, are starting to rust. Finally, the burners are difficult to calibrate, which I really notice when I try to cook rice, which comes out right about 50% of the time.
Now, on top of all this, I have to worry about the glass door exploding?!?! Should I ban my grandchildren from the kitchen? Has anyone from Consumer Reports seen this website?
Posted on Apr 03, 2008
SOURCE: Probe and Bake blink alternately.
I had the same problem. I resolved it yesterday. Detailed instructions can be found if you access my inquiry under the user name bhmlton. If you can't find them, then let me know and I'll get them to you another way.
Posted on Sep 23, 2008
  • 11 Answers
SOURCE: General Electric stove top burner does not light
Sorry for apparently not giving feedback earlier, but the gas valve on the one burner has been replaced, and that solved the problem. What apparently caused this is someone forcing the knob in the reverse direction that broke something in the shaft. It sort of worked for a little while, then would not work at all... no gas coming out = no ignition. I replaced the gas valve with the suggestions given above and all is well.
I you are having problem with your unit, check to see if gas is coming out at all from the burners...you will be able to smell it easily. Then find the pinhole on the side of the burner that is used to ignite the burner when the spark is sparking. clean this pinhole out with a toothpick or small wire...really make it clean as small obstructions can prevent it from working. Then clean off the small electrode with fine sand paper and use the toothpick to remove any food particles on the electrode and the insulator around it.
Now looking again at your comment - no ignitor-... if this means no spark, clean the electrodes ...if itstill doesnt work , one of the gurus can specify the component that generates the spark(s) and troubleshooting procedures for that.
To the person who had no gas, that sounds like a main gas valve problem (regulator?)... resend that question to the gurus as you seem to have something blocking the regular flow of gas for the whole unit.
good luck
Posted on Sep 25, 2008
How to fix la germania burner?
Guess you mean a kitchen appliance not a cd/dvd burner! The only way to help you giving some advice about how to fix ut is if you tell us the problem you need to fix.
Describe your burner: is it a gas burner or an electric burner?
Had you repaired something similar before?
In any case, watch some youtube tutoriasl to repair a burner
Cooktop Range burner not heating burner light is on GE Hotpoint RCA...
GE Hotpoint RCA Gas Stove Repair Burner is not working JGSP44BEY3BB
Prego Project Fix GE Stove Burner
Stove Oven Range Burner Repair Diagnostic GE Hotpoint Kenmore Sears RCA...
Aug 19, 2015 | Computers & Internet
How do you get the GE externa series stove to fire? the gas stove will not light.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 03, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
Jun 15, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
I have a GE JGB920 Gas Range problem. One igniter does not work. How do I change out the igniter?
Most gas ranges only have one ignitor (for the burners), so if one of the burners is not working, I would inspect the connection between the ignitor and the burner...not the igniter itself.
Jun 15, 2009 | GE Profile Spectra JGB920 Gas Kitchen...
Burner won't light
Take the pot support and the burner cover off and clean all the slots out with a toothpick. Carbon builds up over time and the gas doesn't flow over the spark. Do not light until fully reassembled.
Feb 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Right front burner control
its gas. use only qualified engineers for this repair you only have to see what happenson a diy fix once . im corgi registered but will not give out soloutions for gas work.
Jul 11, 2008 | GE Spectra JGBP35 Gas Kitchen Range
if not post your email i will send you the service manual
Mar 15, 2008 | GE Profile Spectra JGB920 Gas Kitchen...
GE Profile Spectra JGB920 Gas Kitchen Range Logo
60 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
