Question about Pioneer Car Audio & Video
Pioneer head unit in a 2007 Ram 1500 issues!!!
After installing a pioneer head unit, my speedometer has stopped registering, also the ABS, Brake, and Check engine lights have come on. If I disconnect the negative battery terminal the check engine light will be off for only a few seconds before coming back on. The head unit works properly. Any help?
  • 23 Answers
From where did you get the direct 12v and ignition? From where the OEM stereo used to be or did you got it from a different location?
Posted on Nov 26, 2013
SOURCE: Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Posted on Jun 25, 2007
SOURCE: loud engine noise through speakers
here we go again. i just had the same problem with my pioneer 1900mp. a little research found something out. with the pioneer units, they have a problem with the rca pre out jacks. they can burn out as soon as a little bit of electricity gets into them. of course i tried everything to diagnose the "engine" noise. but nothing worked, so i tried running speaker wires to the high inputs of my 4 channel amp, and the noise was gone. it's your pre outs, unfortunately. but fortunately for you, if it's still within the warranty period, they will probably work something out with you. pioneer customer service is wonderful. give it a shot.
Posted on May 07, 2008
SOURCE: What wiring harness and deck install kit?
My husband and I just installed a Pioneer DEH-2000 MP today in my 2004 Sentra, which we bought at Electronic Express. They didn't have the wiring harness or the install kit we needed, but Best Buy did. Just go there or some other electronics/car audio place and tell them what vehicle you are installing your stereo into. Make sure you do have all the same color wires and numbers of them on your harness(s) as you do for your stereo - they should of course match, and the plugs of the harnesses will match those of your truck. Don't freak out if you don't use all the plugs in your truck though - one may be left because it was proprietary to your stock radio. A couple of good install kit brands are Scosche and Metra - both use factory colors and molding that will match the color and lines of your dash to make it look as integrated as possible.
Hope that helps!
Posted on May 27, 2008
SOURCE: wiring diagram
nae luck haha
Posted on Oct 26, 2008
smarthome2
  • 1114 Answers
SOURCE: im looking for a wiring diagram for pioneer deh
http://safemanuals.com/annexe_1_PIONEER_DEH-P3550MP-_E.htm
Here's your manual. hope this helps
Posted on Jun 25, 2009
Why are abs, oil, brake lights coming on, speedometer stops working, ac stopped cooling?
That's still under warranty, is it not? Take it to the dealer - let the manufacturer pay for the fix.
Aug 10, 2014 | 2010 Scion xB
Fuses panel described in English
Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
Drivers kick panel:
Front wiper 20A - Front wiper system Cigar 15A- Cigarette lighter Audio 10A- Audio, remote control mirror Air Bag 10A -Air bag diagnostics Stop lights- 15A -Rear brake light, high mounted stop light ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch ABS 10A- Anti lock brake system control unit ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator IGN1 20A - Ignition switch ABS 30A- ABS pump motor TNS 30A- Tail light, license plate light COOL/FAN 30A- Cooling fan Cond/Fan 20A- A/C condenser fan Starter 15A- Start signal , Fuel pump Blower 25A- Blower Motor SR/ACC 10A - Ignition switch Hazard 15A - Hazard and turn signal light D/Lock 25A- Door locks ABS 30A - Anti lock brake system control P/W RH 20A- Power window motor right hand P/W LH 20A- Power window motor left hand IGN2 25A- Ignition Switch
Engine compartment :
Head 25A- headlights IG 2 30A- Ignition switch IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector. O2 down 10A- Rear O2 sensor O2 up 10A- Front O2 sensor Fuel pump 10A -Fuel pump unit Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor. A/Con 10A - A/C compressor controls, cooling fan BTN 30A- Brake light , high mounted stop light. Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination Head low 15A- Headlight Head Hi 15A-Headlight Horn 15A- Horn jlmacman.png jlmacman_0.png
Mar 07, 2011 | 1995 Kia Sephia
My speedometer stopped working ,my abs light stays on and my check engine light stays on and the brake light stays on
Check the "tone wheel" and magnetic pickup that sends the signal to the speedo, also to the ABS, and possibly integrated into the brakes for brake light.
It is one magnetic pickup that controls these three lights. As far as Engine goes, get the car to an Autozone (if it is safe to drive) and they will check all your codes, including check engine, with their scanner for free and identify the location of the problem for you for FREE!.
Hope this helps.
Oct 22, 2010 | Dodge Ram 1500 Cars & Trucks
Uncle put new brake pads on vehicle (he worked on front and back brakes) and now the speedometer doesn't work, the abs light is on, check engine light, and the break light is on. what could have happened ....
Check for disconnected ABS sensors. The front sensors in the front are located next to the axle shafts. The rear sensor is located on the rear differential housing itself on top, in the middle. The ABS is monitored by the computer for performance. The ABS kicks on when the vehicle comes from a certain speed to a dead stop, keeping the wheels from locking up. That could be the reason for the speedometer not working. Or it could be a bad speed sensor. Both can also trigger the check engine light because it is monitored by the computer. The brake light usually comes on due to low fluid level. It can trigger the light, but not be low enough to impact brake performance. I hope this helps.
Oct 16, 2010 | 2000 Dodge Durango
Speedometer and Odometer quick working. How do I
Follow the speedometer cable from the firewall, down to the transmission. It should bolt in the transmission, remove the cable from the transmission, and turn the gear to check to see if speedometer is working, if not, it's most like the speedometer head unit.
Mar 15, 2010 | 1990 Geo Prizm
Volvo abs lights stays on
Usually the ABS computer knows what it is doing. You may want someone to hookup a scanner to the ABS test port.
When I had my speedometer and odometer act up, it turned out to be a bad alternator. You might want to check yours.
Jul 25, 2009 | 1999 Volvo V70
Transmission doesnt shift abs & brake light on speedometer doesnt work
I had the same problem with ABS light and speedometer, I was told that it is the transmission control module. It has not yet stopped shifting but I have had times where it just wont stay running. It will start and then stall. Hope this helps.
May 11, 2009 | 2008 Dodge Ram Pickup 1500
Super duty speedometer problem
ABS fault is your clue. Repair the faulty ABS unit, (one per axle) could be a reluctor or the ABS unit its self.
Dec 19, 2017 | Ford F-350 Cars & Trucks
Speedometer, RPM, ABS, and Brake light
It's not the fuse. You need to jump start the diagnostic cable. First you need a battery of 9v and short the + and - terminal to the diagnostic cable. Then you will see smoke. After that it should work fine.
Dec 20, 2008 | 2001 BMW 5 Series
Car Audio & Video Logo
48 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
