SOURCE: how do I restore factory settings on my dell
Turn
off and reboot your computer. When you see the Windows flash screen,
depress "CTRL" and "F11". Be sure to press them simultaneously and
release them simultaneously.
Select "Restore" in the "Dell PC to
restore by Symantec" window and press "Enter".
Highlight and
select "Confirm" when the message shows that you wiill lose all data if
you continue. This will begin the restore process. It usually takes
about 10 minutes or so. When it's done, you should receive a message
that states the system recovery process was successful.
Select
"Finish" to complete the process and restart your system.
Shutdown
and restart your computer. Keep pressing "F8" until you see the
"Advanced Boot Options" menu. You must depress the keys before the
Windows Logo screen appears. If you wait until after the screen appears
and then press "F8", it's too late and you'll have to reboot the system
and try again.
Navigate to the "Repair your computer" option
Select
the appropriate language and click "Next".
Sign onto the system
as an administrator. Without administrative privileges, you will be
unable to perform the system restore.
Select "Dell Factory Image
Restore" and click "Next".
Place a check in the check box next to
the text that says "Yes, reformat hard drive and restore System
Software to factory condition" and click "Next".
Click "Finish"
to complete the process. This will reboot your computer.
SOURCE: webcam of inspiron mini 1012 is not working. is it
Yes, it is only because of drivers. Install drivers but make sure that you install it for the correct OS that you are using.
SOURCE: WHAT IS THE CAUSE OF 9 SHORT BEEPS IN DELL
Usually a system beeping is what's known as a post code- and can indicate a severe hardware problem. The likelyhood is you need to contact 1-800-456-3355 (dell technical support) since the research I've pulled up for a 3-3-3 beep code is "Motherboard has failed"
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
SOURCE: I have a Dell Inspiron Mini Laptop 1012, how do
You will lose all your data if you wanna set it to factory setting ,have its back up before you loose it.
Here is how to restore at Factory Setting..
1: Restart the computer, click Start, click the arrow next to the Lock button, and then click Restart.
2: As restarts, press the F8 key until the 'Advanced Boot Options' ,menu appears on the screen.It should come up before Window logo appears.
3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
4. Specify the language settings that you want, and then click Next.
5. Log in as a user who has administrative credentials, and then click OK.
6. Click Dell Factory Image Restore.
7. In the Dell Factory Image Restore window, click Next.
8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
9. Click Next. The computer is restored to the default factory configuration.
10. When the restore operation is completed, click Finish to restart the computer.
