Question about Koss Audio Players & Recorders
Need correct ac adapter for KOSS 6v computer speakers
Open SKy
  • 618 Answers
SOURCE: Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
Posted on Oct 17, 2008
SOURCE: Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Posted on May 07, 2009
dickgs
  • 22 Answers
SOURCE: I NEED AN AC ADAPTER FOR MY YAMAHA YST-M7 POWERED
Check this... its the nearest specs I've found... Good Luck.
http://cgi.ebay.com/AC-DC-Adapter-110-220VAC-to-1-5-3-4-5-6-7-5-9-12VDC_W0QQitemZ200415259300QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9ae2aa4
Posted on Dec 12, 2009
SOURCE: I cannot locate AC adapter for speakers MIL 699 remote speakers
I found the AC adapter for the speakers 120 Volts AC in and output 7volts 500Ma
Posted on Dec 16, 2009
kc5uzd
  • 13 Answers
SOURCE: need ac adapter for speakers
If you're in the US, go to Radio Shack and buy a plug in transformer that puts out 12VDC at 1000mA.
The polarity is negative (-) on the outside and positive (+) on the inside.
Posted on Apr 28, 2010
Power requirements required are 6 volts dc at what amperage?
6V DC 200 MA; plus shell, minus center pin
aka, Panasonic AC Adapter Model No. RP-65A or equiv..
Nov 29, 2013 | Labtec LCS 150 Computer Speakers
I have koss HD30 2pc. Amplified speakers and I need an AC wall adapter for them. What is the proper adapter for these?
If i remember correct should be between 6V to 9V at 800mA or 1A...if you plug the higher value adapter does not harm your speakers anyway, hope this helps...
Sep 17, 2013 | Video Game Consoles & Games
Hiw many mA does the adapter for labtec lcs150 speakers need
You want to make sure the plug at the speaker end is wired properly: + on the outer barrel and minus on the center pin (the adapter will have a little graphic for verification purposes). If so, your 500ma adapter should work fine. The voltage might be a little high but nothing the speakers cannot handle I would think.
Mar 29, 2013 | Labtec LCS 150 Computer Speakers
NEED TO REPLACE POWER SUPPLY
Nov 12, 2012 | Labtec LCS 150 Computer Speakers
Hello everyone! I have lost my Koss HD50 power supply and was wondering again, how many volts and how many amps? ex:6V, 500ma Thank you kindly! Erjel
Three C cell size batteries per speaker is what you use if you are on the go.
http://www.shopping.com/Koss-HD-50/the-paradox-decent-small-computer-speakers/1386310/reviews#tabAnchor
Hmmm.
EACH C cell battery produces 1.5 Volts (DC)
3 times 1.5 Volts (DC) = 4.5 Volts
Total of 9 Volts (DC)
500 MilliAmps?
Your main concern is with the Voltage.
The Amperage can vary. It can be more than needed.
Why?
Because Amperage represents Current.
How much Current is available.
(Water hose example;
Voltage is the speed, or velocity of the water coming out. Amperage is how many gallons per minute that comes out of the hose)
However, you better make sure that EACH speaker receives No more than 4.5 Volts (DC)
Since you do not have the special splitter adapter cord that comes with the power brick, you will have ensure that EACH speaker receives no more than 4.5 volts.
This is if you are trying to use a 9 Volt (DC) power supply. (AC adapter)
Please post additional questions in a Comment.
Regards,
joecoolvette
May 30, 2011 | Koss HD 50 Computer Speakers
What voltage are the koss 'older' computer/CD speakers that would take 3 'C' batteries each. I have a variable voltage adapter and am not sure if I should switch it to 9 volt or another setting for AC...
C cells are 1.5 volts each. If the speakers use three of them that means you'll need a 4.5 volt supply. If each speaker needs batteries, you'll need to feed that voltage to each speaker, and the supply should have enough current for the total load. A 1-amp rating is probably fine.
Dec 24, 2010 | Koss HD 50 Computer Speakers
Need power supply -- what are compatible power supplies?
Take a look where the power-adapter connects into the speakers. Also, look on the "brick" of the power-adapter.
Look for 'AC' or 'DC'.
Look for '6V' or '9V' or '12V' or '18V'.
Look for the Amperage rating.
If 'DC', look for the small pictograms, either:
* ring-positive-post-negative, or,
* ring-negative-post-positive
With that information, check Thrift Stores, and then check the "big-box" computer stores.
Jun 09, 2010 | HP Compaq JBL Pro (401508-001) Computer...
I only need the AC Adapter Campanion 2 for my Bose spearkers. How can I find just the adapter?
Look where the AC adapter would plug in.
Look for "rating", e.g., 'DC' or 'AC',
and '6V' or '9V',
and look at the size/shape of the plug.
Then, go to a "Dollar Store" or "Thrift Store", and try to match the ratings and the plug-layout with the available inventory.
Or, contact BOSE, and see if you can buy it from their web-site.
May 28, 2010 | Bose Companion 2 Computer Speakers
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
59 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
