Dwc-ed1212 daewoo washing machine - Washing Machines
4 Suggested Answers
reddyanantha
  • 205 Answers
SOURCE: water pouring out from under my washer as it fills...
hello mam please check the rubber sleeve of the drum if there is any crack it should be replaced and check the drum if there is any holes in it, so please call the engineer and make him to check these.
Posted on Sep 29, 2009
  • 6277 Answers
SOURCE: I have a new machine
(the following notes are pre-typed but well worth following through- for later as well!)
I suspect that it is the conditioner/softener tray needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of those should enable you remove it
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
IN YOUR CASE IS IT STILL UNDER GUARANTEE/WARANTEE? If so call them in!!!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 09, 2011
  • 6277 Answers
SOURCE: I can't close the door
Sorry but you will need to call a local service engineer as there is nothing else we at the FixYa forum can suggest. Members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer but hopefully assisting with most problems;-0)
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Posted on Aug 22, 2011
I have a washer dryer combo (daewoo DWC-LD1412) am I able to use the dryer without having to do a load of washing?
check the hand book ( download from the net if you have lost it) you should be able to program it to dry with out a wash as you should be able to hang the washing with out using the dryer
Jun 25, 2015 | Washing Machines
Model DWC-LD1421 WHAT DOES FAULT CODE LE MEAN ON THIS MODEL
this is the code issue for the Daewoo washers things to check The washing machine or washer dryer door has been detected as open or unlocked.
  • Close the door!
  • Check the door lock switch
  • Check the door latch
  • Check PCB
Mar 09, 2015 | Washing Machines
Daewoo washing machine model number DWC-LD1421 what dose the fault code LE mean for this model
  • Close the door!
  • Check PCB
Mar 09, 2015 | Daewoo Washing Machines
My Daewoo DWC-UD1212 washing machine does not spin; and shows IE whenever the light indicator is on Spin. What should I do?
not sure bout the IE error But I would check the clutch, the motor coupler, the door switch, and the belt if applicable?
Feb 28, 2015 | Daewoo Washing Machines
DAewoo DWC-LD1013 will not spin
The Daewoo DWC-LD1013 is a washing machine, you may wish to post your question in that category, not in air conditioners.
Jan 09, 2015 | Daewoo Heating & Cooling
Installation instructions DWC/CV701PC
Is this : http://www.daewoo.cl/sta/manuales-tecnicos/Manual%20Tecnico%20DWC-300M.pdf what you are looking for?
Oct 07, 2014 | Washing Machines
THE ERROR IS 63 THE WASHING MACHINE MODEL IS DWC-ED1212
Under the machine should be a bag with
the diagnostic manual & codes
Aug 17, 2014 | Washing Machines
Daewoo DWC-UD1212 Washing Machine
Washer machine when I select manual wash , LE letter show on program monitor , and washer machine is not work.
Aug 29, 2013 | Daewoo DWDWD3011WW Front Load Washer
Water pouring out from under my washer as it fills...
Sep 29, 2009 | Washing Machines
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
