Question about Compaq Presario CQ56-115DX Laptop
Laptop has no picture and caps lock button is flashing
Laptop was frozen, so I pressed the off button until it went off and when I turned it back on, it never went to the screen asking if you wanted to start in safe mode etc... It just sits there with a blank screen and the caps lock button is flashing
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
Open the ram memory cover and remove the memories module a d clean the contact wire with soft cotto. Cloth an re-insert and start the computer. Maybe it helps
Posted on Nov 20, 2013
Testimonial: "I tried this, but no such luck. I have found out that the one blink on the caps lock means a bad CPU problem. Think I am in trouble."
  • Debbie Lowe
    Debbie Lowe Apr 03, 2015
    I have also tried this for my problem but it does nothing. Other suggestions have aimed at starting the laptop in safe mode, however, this is impossible as I only get a blank screen strat from turning it on.
SOURCE: Laptop start up problem
go into bios and turn off virus i assume you have xp
Posted on Oct 25, 2007
  • 38 Answers
SOURCE: my laptop power button keeps flashing on and off
This is a first step, a bit of magic that frequently works.
Try a Hard Reset according to HP's instructions at
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01684768&tmp_task=solveCategory&lc=en&dlc=&cc=us&lang=&product=95524
Good luck
Posted on Nov 28, 2009
SOURCE: Compaq Presario CQ45 screen remains blank... help
Open the Notebook from the back side and locate the RAM. Now remove the RAM and place it again and check, you can even try inserting the RAM in different slot if any used slot is available.
Check out.
Posted on Feb 12, 2010
  • 214 Answers
SOURCE: when i press the power
I believe blinking lights on the Caps and NumLock means that there is a problem about the Hardware, I've been a Tech Support for HP and those blinking lights are problems for Video Card, CPU, Memory.
It would be better if you call the manufacturer try if they can service your machine.
Hope it helps. =)
Posted on Apr 19, 2011
Geekman
  • 32281 Answers
SOURCE: PRESARIO CQ57-356EA SCREEN IS BLANK BUT IS POWERING UP
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Feb 09, 2012
HP laptop 6530S is not starting?
The caps lock button flashing is a code to tell you what the problem is.
Count the flashes and get back to me. They will pause between counts, but if it is one it just flashes slow.
Apr 04, 2014 | Computers & Internet
Caps lock light flashing and laptop not responding
Hello.
Disconnect all power. Flip the laptop to unlock and remove the battery. Reinsert and lock the battery. Power on, again.
Hope this helps.
Jan 05, 2012 | Dell Keyboard for Inspiron 1300 B120 B130...
SCREEN WENT BLANK ON MY HP PAVILION LAPTOP. REBOOTED AT LAPTOP BOOTS UP FINE, BUT STILL HAS BLANK SCREEN. AUDIO WORKS, AND CAP LOCK AND NUM LOCK FLASH. dtcorman@comcast.net
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens,there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this will help...Your response is very much appreciated...
Jan 21, 2011 | Computers & Internet
We have a new Acer Aspire one and the mouse is frozen. When I try to turn off the unit nothing happens. How do I free the unit or turn off everything?
As this was posted a month ago, I'm presuming you've solved the problem?
However, when your laptop locks up completely, the mouse won't move and the keyboard is unresponsive (press the caps lock key and see if the caps lock LED comes on or off?)
Press and HOLD the power button for a few seconds until the laptop powers off, Wait a few seconds and then power it on again, the computer may moan that it wasn't shut down correctly, but this is normal (because you couldn't shut down correctly)
Jan 15, 2011 | Acer Aspire One A150-1006 Notebook
Have bosch classixx6 1200 express which has frozen displays a flashing key and 36 will not budge, desperate Molly
Simply press and hold the Start button for 4 seconds and the childproof lock will turn off - the key symbol will disappear from the display.
If you want to activate the lock then press and hold the Start button until the key symbol appears on the display.
Oct 22, 2009 | Bosch Washing Machines
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Will not power up, no fans, post code or display
when you say you press the reset button you mean the power button right?
I assume you just press it and pc restarts...
instead bootup to as far as you can get then press and hold power button until pc turns off then reboot ..you should now be able to access the point where it says windows was shutdown incorrectly or interrupted options to restart normal or last good config etc..
if it doesnt you may need to reinstall windows
Jan 13, 2009 | HP NX9010 Notebook
Compaq Presario CQ56-115DX Laptop Logo
112 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
