Question about Acer PD726W Projector
Lamp problem on ACer PD726W
Acer PD726W was working fine. No warnings for end of lamp life as indicated in the manual. Next time I turn it on, it shows the lamp light to be red. No projection, no lamp. Any ideas?
Asc
Posted on Nov 20, 2013
How do I reset the lamp timer on an Acer X1320WH
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Here is the manual in PDF, on page 33 you can see how to reset the lamp hours.
http://www.roscorrentals.com/equipment_manuals/Sony%20VPL-PX31.pdf
Dec 21, 2013 | Computers & Internet
The little orange light next to the regular green light that appears when the tv is on is lit up....I suppose it has to do with bulb however the tv appears to work just fine...what does this light mean
Yes,the tv projection bulb life is ending.Sometime the LED light indication "LAMP"light up or blinkig,tv still work,because it just giving u a little advance warning that all.The "LAMP" LED indicaton light,light up right?
Sep 14, 2010 | Zenith Z52SZ80 TV
Indicator showing LAMP. Does this indicate the lamp needs replacing?
Yes. The lamp is timed and the replacement indicator signals when the lamp is near end of life. If the lamp fails catastrophically it makes a mess... best to replace before that happens.
Jan 03, 2010 | Dell 3400MP Multimedia Projector
Acer 4520g minitor blackout
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 14, 2009 | Acer Aspire 3680 Laptop
Acer screen looks dark?
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 23, 2009 | Acer Aspire 5315 Notebook
No screen
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 09, 2009 | Acer Aspire 6920 Notebook PC
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Compaq 7550 monitor keeps turning pink. Works fine for a few minutes then back to pink and hard to see. Sometimes moving the mouse quickly will help but only for a few minutes. Have tried adjusting all...
Defective CCFL backlight may has the following symptom:
· Screen flashs on red/pink and off.
· Picture stays on in red and slowly be come normal.
· Picture flickering with dim display.
· Picture flickering on and off.
Mar 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer pd726w projector beeps
I hate to echo this problem, but did either of you ever find the solution to beep code? Our church has had the projector for just two years and the lamp must have only about 400 hours on it.
Oct 20, 2008 | Office Equipment & Supplies
Acer pd 112 projector
Please reset lamp hours to zero and clean its air filter located to its bacside (Bottom)
Mar 16, 2008 | Office Equipment & Supplies
Acer PD726W Projector Logo
113 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
