How To Reset Ink Counter On An Epson CX7300, CX8300 or CX9300
You must set the date in your computer to "April 11, 2008" to run Resetter Epson CX7300, Epson CX8300 and Epson CX9300 without error. If do not alter the setting of date of according to rule then software will deleted automatically when running.<br /><br />If you have an error, delete all following entry before you rerun the software.<br /><br />delete registry key: <span style="font-weight: bold;">HKEY_LOCAL_MACHINE\SOFTWARE\EPSON\PTSG</span><br /><br />and delete folder: <span style="font-weight: bold;">C:\adjustment program</span><br /><br />To reset waste ink pad counter Epson CX7300, CX8300 and CX9300F use adjustment program. I have tried this software and this software worked. To run this software without error please follow the instructions above.<br /><br />Here How to use this software:<br />
<ol>
<li>Download the adjustment program (see below)</li>
<li>Extract the file you have downloaded</li>
<li>Go to The extracted folder then click tricks-collections.bat file</li>
<li>Now set the date setting in you PC to 11 April 2008,</li>
<li>Run adjustment program by click AdjProg.exe file the click accept</li>
<li>Click Particular adjustment mode then select destination and printer port then click OK</li>
<li>Select Waste ink pad counter from the below window and double-click to execute it</li>
<li>Click [Check] button to check current protection counter's value.</li>
<li>Then Click [Initialization] to reset the protection counter to the initial value.</li>
<li>After finishing, you can change the date back to normal.</li></ol><b><br />Link Adjustment program for Epson CX7300, CX8300 and CX9300F</b>
<ul>
<li> Adjustment program for epson CX7300: <a href="http://www.mediafire.com/?8wrkugah2mj">http://www.mediafire.com/?8wrkugah2mj</a></li>
<li> Adjustment program for epson CX8300: <a href="http://www.mediafire.com/?0xfnrgarvuj">http://www.mediafire.com/?0xfnrgarvuj</a></li>
<li> Adjustment program for epson CX9300F: <a href="http://www.mediafire.com/?o020wlaf6te">http://www.mediafire.com/?o020wlaf6te</a></li></ul>
<br />
