Question about Samsung SCX-4200 Series
Paper jam 2 scx 4200Hello, my Samsung scx-4200 had a paper feed problem.When i try to print 1 page of something, the printer takes 1 paper, and then continues to take paper after the first and then there is a jam.Problem is that the rubber pickup roller just keeps spinning and spinning, it is supposed to stop spinning when the sensors tell the roller that the paper has reached the next checkpoint.When the paper reaches the next checkpoint, power goes off from the electronig magnets releasing the stopper to the pickup roller.However, between the electronic magnet and the stopper there is some soft material.My problem was solved after about 25 hours of googling and unscrewing the machine.Problem was that the soft material had gotten so sticky that when the power went off from the magnet, the stopper still wasn't released because it was in the sticky material.I removed the soft sticky material from both of the magnets and now my printer is working like a charm.Thanks.
  • chrisdobb224
    chrisdobb224 May 27, 2015
    Hi, thanks for posting this! I believe I have the same problem. However, I'm having a hard time finding the magnets/stopper that you are referring to. Here is a link to the service manual showing all the parts. Could you please indicate which parts they are? (Diagram number and part numbers) I would appreciate it very much!! Thanks in advance.
  • chrisdobb224
    Oops -- the link:http://www.arbikas.com/view/locator/SCX-...
  • 3 Answers
Try this, inside the printer, normally when you open the case/ink port, you see all the paper feeding gears and rollers. You really don't have to be a tech for this, just make sure there are not any flakes/small pieces of paper inside. This is when its good to have a can of compressed air, available at many electronic stores, and "blow" out the dust/paper. This helped with my printer. Also, make sure all the paper feed areas are lined up and working. Watch how far the paper feeds into the printer, then look what is at that point in the printer. Best Wishes, CD
Posted on Nov 20, 2013
  • Chad Douillard
    Chad Douillard Nov 20, 2013
    I guess I should have read the previous answers!! hahah
eagle338
  • 4889 Answers
SOURCE: pixma mp460 error 5100
this error is an error within the printer. This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or in my case popcorn. There was even some paper caught underneath the rollers that I had to jiggle around to even see. Check VERY thoroughly.
Posted on Oct 19, 2007
  • 13433 Answers
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
  • 9 Answers
SOURCE: HP 4700n Paper Late Jam
duplex area related jam in other printers. is problem only occurring in tray 1. If so, there is a problem with the tray. If it's happening from tray 1 and tray 2, replace try replacing transfer belt.
Posted on Sep 16, 2009
  • 360 Answers
SOURCE: Samsung scx-4521F giving me document jam error
hello please check it properly.some time their have a small piece of paper.
or clean adf unit & service.
Posted on Sep 09, 2010
hattinghbr
  • 214 Answers
SOURCE: My paper is getting stuck on roller for laser printer scx-4521f
open the front door and take the cartrige out.
if it jams at the black roller. you must clean the pickup roller.
you will see it at the back of the unit in the center.
Posted on Oct 06, 2011
Samsung SCX-4300 paper jam
sir i have samsung scx 3201 printer but paper loading problem so plz solloved my problem
Oct 23, 2012 | Samsung SCX-4300 All-In-One Laser Printer
The document printed from samsung scx 4200 printer has smudges and dots.
When you say smudges, can you wipe the toner from the page with your fingers; or is it just smearing when it prints; but, the toner is affixed to the paper?
1) If you can smear it with your fingers; replace the fuser. It's not heating the toner properly
2) If it is smearing, but sticking; replace the DRUM.
Nov 07, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Chris asks. My Samsung SCX-4200 is showing ( add paper no paper and PC print pending ) on the led
Check and Cause:
1. Deformed paper sensor actuator or faulty sensor.
2. SMPS PBA or Main PBA is defective
3. Faulty cables or connectors.
Solution:
1. Replace the defective actuator or sensor.
2. Replace the SMPS PBA or MAIN PBA as
appropriate.
But better - take MFP to authorised service center
Nov 30, 2009 | Samsung SCX 4200 All-In-One Laser Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Always paper jams and doesn't feed correct so pages printed as wanted
Check the are where you load in the paper for any foreign debri and rollers. Make sure the rollers are straight. Don't forget to check the other end where the paper comes out too.
Oct 29, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam Error 2
Don't try a dozen things suggested by people online who's credentials are unknown. Go straight to the source.
I had the same issue and just went to www.samsung.com - looked up my model #, downloaded the PDF manual 86 pages and did a search for that error. It had step by step picture diagram of how to clear out the jam.
I just saved the company a few hundred on a service call to our printer sales/service vender.
Oct 28, 2007 | Samsung SCX-4100 All-In-One Laser Printer
[no paper] in SCX-4200
there 9is a paer sensor which senses when there r papers ,prob might b that either it is not functioning or on of the sensor is depressed
Jul 29, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Computers & Internet Logo
265 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
