Servis m9503 washer dryer keeps filling while washing.It just wont stop filling with water. Have changed the pressure switch,cleaned the pressure chamber,pressure switch pipe is clear and the drain hose in the right height. Am bemused by this fault
  • Washing Mach... Master
  • 17,130 Answers
The problem can be found if you can check if the pressure switch contact is working and sends the signal back to the controller unit. If not there is fault in the wiring as you have replaced the switch.
Also if the switch works then the controller unit is at fault and is not reacting to the input from the water level sensor.
Posted on Nov 21, 2013
mohammed387
  • 1952 Answers
SOURCE: washer will not drain water or go into rinse and spin cycle
First thin I would try is to check your thermal fuse for continuity. Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd and tends to collect lint. Run a coat hanger up the hose and see if you can fish something out also check that belt.
Posted on Oct 06, 2008
aborcass
  • 2651 Answers
SOURCE: kenmore elite h4 washer fh code
F/H is a no water fault code, so i would recheck your incoming water supply, or look to a problem with the inlet water valve.. if your using stainless steel hoses, form the manufacture lableld FLOOD SAFE, these maybe your issue as well they have a buitl in water shut off, htat may be failing preventing water from entering
Posted on Nov 30, 2008
  • 52 Answers
SOURCE: Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Posted on Feb 28, 2009
  • 10 Answers
SOURCE: zanussi washer just keeps on trying to drain
this is the electronics on the machine reacting to a fault .the electronic has detected an electrical component fault .for example a motor gone short circuit you can only find out what by testing the components with a suitable test meter or by acessing the machines own diagnostic facility and retrieving the error code .if cant test with a meter you need the manufacturers service engineer
Posted on Jul 31, 2009
jan mczeal
  • 632 Answers
SOURCE: M9503 washer dryer not draining before dry cycle.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Aug 22, 2009
How do I stop the front loader (washer/dryer from flooding my rv?
If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
If the pressure switch is fine, check the water inlet valve for continuity on the solenoid coil by removing the top cover of the machine.
Sep 14, 2014 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Servis m9503 washer dryer continuously fills with water,pressure switch and tube are ok,pressure chamber cleaned out and drain hose right height
if u checked the pressure switch aand its ok then look at your water inlet valve?
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed
By the way my advice is free cuz God is good!
Nov 20, 2013 | Equator EZ 3612 CEE Front Load...
Stackable washer dryer
there's a water pressure switch that when the water fills the pressure switch gets satisfied and then stops the water and then sends power to the timer or board depending on what machine you have,if the switch doesn't close the washer will just keep filling.the switch could be bad or also there's a clear plastic hose that goes from the switch to the side of the tub,sometimes detergent or or junk that can form in the hose can cause this,i use a plastic tie or a paper clip ,pull off the hose where it connects to the tub and clean it out with the paper clip,if you have an older machine you can blow gently into the hose and you'll hear like a click sound from the switch,if the hose is clear most likely it will be a bad pressure switch.next time send the brand name and model number so whoever is helping you can look up your machine.all washers are not the same
Jul 10, 2013 | Dryers
Water wont shut off
Hello, Thank You for using FixYa. I will be helping you today.Unplug the unit if it still fills replace the fill valve. If it stops filling when the porwer is off and keeps filling at start of a cycle it would be the pressure switch or pressure hose came off. The pressure switch is the water level selector switch and the hose goes from it to the tub.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Kenmore 98702 Stacked Washer/Dryer
Washer overfills, dosen't stop filling even after I cut washer off
bad water level switch or the clear plastic hose has a hole in it or popped off the water level switch or the pressure switch same thing.the switch works by pressure,if there's a hole in it or the line feel off there's no pressure and the switch keeps calling for water,shut the water valve off
Jul 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer fills with cold water but does not stop filling
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
OR
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Sep 15, 2009 | Maytag LSE7806A Top Load Stacked...
Check these out:
Aug 22, 2009 | Hoover AAA140 Front Load Washer
Keeps filling with water
The water level in a washing machine is determined by the pressure switch. The switch is located behind the load selector, water level, load size (has various names depending on model and manufacturer) knob on the operator console. If the switch malfunctions, the water will not shut off and the washer will overflow.
Now...before assuming the switch is defective, a common problem that occurs is the small air hose on the pressure switch coming loose or leaking. This air hose attaches from the wash tub to the pressure switch. The pressure swtich senses the change in air pressure as the tub fills and shuts the water off at the selected level. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
To access your pressure switch, unplug the washer and open the operator console. Look for a clear plastic hose. If it is NOT attached, you may have found your problem. Reconnect and test operate.
If it IS attached, check the entire length of the hose all the way to the wash tub for any cracks of leaks. In addition, remove the electrical connection(s) and check for corrosion. Clean if necessary.
If all these preliminary steps don't solve your problem, replace your pressure switch. Read through the link I provided and let me know if you have any questions. I hope you find this information helpful.
Jun 12, 2009 | GE WJSE4150B Top Load Washer
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
