Question about Dishwashers
Ge dishwasher gld4550n10cs
WON'T START OR FILL. CHECKED POWER,OK REPLACED FILL VALVE. STILL NOTHING HAPPENS
catriver
  • 878 Answers
SOURCE: Power going to dishwasher but nothing happens??
Gina, you probably blew a thermal fuse that sits on the control board. Easy fix. Have your husband first check the wiring to the dishwasher. Remove the toe panel and make sure the wire nut connections are good. If that is ok, he will have to remove the inner door screws to get to the control board. Lift out the inner door. Remove the control board cover, it just snaps off. He will see the thermal fuse on the upper right side. I will attach a photo of what it looks like...Catriver...post back
Posted on Nov 05, 2006
SOURCE: GE Natulus will not fill with water
Had the same problem with ours today. That's why I got on here. My dad used a gallon jug to prime it with a gallon of hot tap water. We primed it to get it pumping, and now it is working fine. Just pour the hot water into the dishwasher and start it.
Posted on Dec 30, 2008
whytfang
  • 170 Answers
SOURCE: Ge Triton XL Dishwasher Fill Problem
I would check your fill valve screen, where your water line connects to the dishwasher, lots of times i will see that screen clogged, especially on customers homes that have wells.
There is no way to change the fill time on these.
There is also the potential problem with the float sticking if it is gunked up it will not allow water in...see that it moves up and down freely and you should here a clicking noise.....If it is not one of these there could be a problem...with the timer...I am providing a link that will help walk you through this problem in a more technical...manner...if you are not comfortable performing these tests...i suggest you forego it and let a tech handle it....
http://www.applianceaid.com/dish.html#filling (http://www.applianceaid.com/dish.html#filling)
this is one continuous link.....you can scroll down until you see the won't issue.
I hope this helps ..good luck, have a good day& please rate my effort......The Fang
Posted on Mar 27, 2009
SolutionGuy
  • 331 Answers
SOURCE: Dishwasher will not fill
EE,
The most likely culprit in a "no fill" scenario (especially after you've replaced the valve) is the Overflow preventer. It's designed to kill power to the valve if the water level gets too high. It does this by floating up as the water level rises.
Open the dishwasher door and remove the lower rack. You'll see it in the tub on the left side (the round thing that looks like a little hat). If it's stuck in the up (overflow) position, you won't get water. Raise and lower this device a few times... you should hear the "click click click" of the kill switch. Now just make sure it's in full down (ready for water) position and fire up the dishwasher. You should get water now.
If this helped, please rate this solution as "FixYa". BUT if this didn't fix the problem, don't rate it just yet. Write back and we'll go a little deeper into a diagnosis, OK?
SG
Posted on May 01, 2009
  • 1891 Answers
SOURCE: My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Posted on Dec 07, 2009
Kitchenaid kudi01ilwh2 won't start
By won't start do you mean that everything is set ok but when you press Start button then nothing happens.
In that case most likely the door is not sitting properly or the door latch or door switch is faulty causing the dishwasher to not start.
However, if nothing happens on the panel when you press buttons but power is there, then most likely the panel is faulty and can be replaced.
you can trace the parts in these diagrams.
Nov 01, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Ge diswasher won't fill with water
When the program is switched on if there is no water flow despite the fact that the inlet flow is good, then the inlet valve is defective. it can be a failed valve if there is no action and if the flow is low then it can be a clogged valve. Remove, back flush and reset, if not replace, provided there is power to the valve.
Oct 22, 2011 | GE 24 in. Profile PDW7880G Built-in...
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Dishwasher comes on but it won't fill.
Hi
Daniel
Aug 21, 2011 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
My ge dishwasher will not fill with water when started
You need a voltmeter to test the water solenoid valve. If the valve is getting power, but does not fill the unit with water, then replace the valve
Jul 05, 2009 | GE 24 in. GLD4100L Free-Standing...
Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Jun 29, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
I have a GE GSD2230Z00WW dishwasher water will not fill on start no power on the fill valve either. Water will come on quick wash cycle and rinse.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
***If everything checks out ok with the water inlet valve, replace the timer or control board.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Dishwasher won't fill on start
Check the following to address this issue.
Dishwasher not filling with water. It is not the float. GE PDW 8480 Dishwasher
It could be the fill valve or that the power is not getting to the fill valve. Pull the bottom panel and find where the water line hooks up to the valve. There should be an electrical connector on the valve. First, listen when the dishwasher is at the cycle where it should be calling for water, to see if youhear a click of the valve opening or water running in. If not, and you have a volt meter, pull the electircal connector and check for AC voltage across it when the dishwasher is off - it should be 0, and when the dishwasher normally would fill - it should be something above 0 - it might even be 110v. If the voltage is ok, but the valve is not working, you need to replace the vavle. If the voltage stays 0, then something is wrong in the timer/control circuitry.
Mar 13, 2009 | GE Dishwashers
Dishwashers Logo
16 people viewed this question
Top Dishwashers Experts
