Question about Maytag MER8770WS 30" Freestanding Electric Range - Stainless Steel
Maytag Range won't heat up oven or cook top
Bought my Maytag range January 2011, so it's not very old. Two night ago I started to cook dinner, turned the oven on to preheat, and started to boil some water. I know that the burner was starting to get hot. Maybe 2 minutes later I noticed a weird smell, almost like a burnt rubber type smell. I opened the oven to check and it wasn't coming from there. The smell went away quickly but then I realized the burner had stopped getting hot and the oven would not heat higher then 215 degrees. What's going on?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
You have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Posted on Nov 20, 2013
  • Amanda Dowd
    Amanda Dowd Nov 20, 2013
    I should've stated that the lights and panel come on but no heat to either. Still internal wiring? Or the control panel not talking to the heating elements?
3 Suggested Answers
SOURCE: high-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Posted on Dec 05, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Maytag cooktop gas range-about 2 or 3
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 24, 2010
What happens when you turn on the pilot light on a Capital Gas Cooktop and cook with it on
you have just triggered an exothermic reaction of light hydrocarbons and oxygen as a result of introducing an external heat source trigger. Which could possibly result in the cooking of some dinner. Yum.
No worries Barbara, you have done no damage. Unless dinner burned....
Feb 27, 2016 | capital Precision GCR486G 48" Pro-Style...
Burners wont work any more
Good Morning Fern mullen, I appreciate your post!
Based off what you have described your burners are no longer working on your Frigidaire range. This could be an issue with your control panel or the switch. I would recommend performing a reset on your range and you can do that by disconnecting power from the range for at least ten minutes. If that does not help correct your issue I would suggest having a technician out to your home for a proper diagnosis and repair. Best of luck! -Matt
Feb 28, 2015 | Frigidaire FGEF306TMF 30" Freestanding...
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
Oven heats up very slowly
how old is your maytag might be time for a new one.
Jan 01, 2013 | Maytag Stove / Oven / Range Cooktop -...
Maytag oven will not heat after self cleaning
try to unplug the oven and let it sit for a bit then plug it back in.
Dec 10, 2012 | Maytag Stove / Oven / Range Cooktop -...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Maytag accellis 2x stove won't heat-up, does power-up, light comes on but no heat
Buy a new stove element. If you open the stove look in the back. It should be black. It might have a crack or be clearly broken. This is a cheap fix. If you want to be sure that it is working at the connection unplug the element and pull it out. Put a volt meter into the prongs. Turn stove on and see if its putting out voltage.
Jun 02, 2012 | Maytag Stove / Oven / Range Cooktop -...
Maytag MER8770WS 30" Freestanding Electric Range - Stainless Steel Logo
102 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
