Question about Refrigerators
Beertender b90 level indicator flashing. Cooling indicator is working fine and and the temp is 42 degrees.
I bought this unit used and it was not cooling and the panel was dead so I replaced the 3 1000 mf caps. It's now cooling fine but the level indicator is flashing. The keg is approx 3/4 full. Any suggestions?
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
42 deg is too warm for beer keg it should be 32 deg possible a warning temp too high
Posted on Nov 23, 2013
DOREEN1
  • 51 Answers
SOURCE: cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Posted on Jan 31, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Posted on Dec 24, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Freezer works fine--Fridge Side Not Cooling Properly
I am sending you a link below to download the manual for your model. There are too many Q&A to do this here and on this page. The manual has some self diagnostic test you can do yourself through the control panel. These are very good refrigerators and they are backed by Maytag. The only problem is they are complex. You can try to find answers and if you have questions I will need to be contacted by email because Fixya has not been sending out anyones responses lately. They know about the problem. Sea Breeze
appliancepartsse@yahoo.com
http://www.servicematters.com/maytag_library/docs/SAM0074.pdf
Posted on Jul 16, 2009
  • 3 Answers
SOURCE: my beertender stopped cooling my keg. what can I
Wondering if you found a solution to this yet. Mine stopped cooling, too.
Posted on Nov 03, 2010
CWC-1600 cools constantly
More than likely, the thermostat on the unit is going bad. If the coils haven't been cleaned recently, then I suggest that you unplug the unit, clean it well and then cycle it back on. If it continues, then the thermostat that's located within the unit is going bad. Please refer to the owners manual for proper service and maintenance for your unit. https://www.appliancefactoryparts.com/content/pdfs/140265-1.pdf
Feb 04, 2017 | Heating & Cooling
Check engine light flashes only til I reach 30 mph, slow while acceleration, engine temp fluctuated from normal to low on temp gauge, engine rpms seem to drop lower than normal? What is wrong here?
the lowering on the temp gauge indicates a lack of coolant around the bulb of the temp sender unit or a lack of flow around the cooling system
could be from low coolant level or blockage in the coolant system from forming ice ( 16 degrees is -8 degrees Celsius which is below freezing point of water)
I suggest that you check the antifreeze ratio in the cooling system and it should be no less than 50/50 to water
any thing less than 50 % antifreeze in the water will allow the coolant to freeze up which may be your problem
coolant condition should be checked every season as it does deteriorate over time and the % ratio will drop
topping up with normal water is another method of lowering the % point
check with a radiator shop or dealer service center to get the correct % of antifreeze for below freezing conditions and keep it at that point
Dec 20, 2015 | 1999 Toyota Camry
Where can I purchase tubes for my beertender B90 in the UK. How do I find out the product code so I can order as there are several differert types on Amazon.
As you have discovered, it is impossible to buy tubes in the UK. They can be ordered from the USA but they cost a fortune and the shipping fees are terrible. The best solution I have found is as follows: Log onto www.eBay.co.uk and enter Beertender tubes into their search engine. Scroll down the first page of the results and at the bottom right hand side select the link (see all matching items from international sellers). Scroll down the results and about the 4th one down is a French retailer selling 30 tubes for 10 pounds. OK, so they charge 20 pounds postage but if you buy 2 X 30 tubes, they postage is about 24 pounds - 60 tubes for a cost of 44 pounds. It is possible to reuse the tubes a few times - make sure the pressure is thoroughly expended and gently prise the tube from the keg. But, hey, I don't really see the point if all it costs is 8p for a new tube per keg. Bottoms up From Dogmanbrian
Jun 19, 2013 | Krups Beertender from heineken and b90...
Beertender wont turn on
You may have a problem with the starter on the unit. It will keep the unit from freezing or cooling.
Feb 03, 2013 | Krups BeerTender B95 Beverage Dispenser
My beertender is not cooling
Does the compressor kick on? What is the model number listed on the unit?
Nov 01, 2012 | Krups Refrigerators
Everything works, except the appliance doesn't absorb nor eliminate the humidity; the pan doesn't fill up and the hose doesn't spew out any water. The electronics seem fine in that the power...
As I tell all the folks who report the same problem you have. There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 and 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
in basement applications level. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 24, 2011 | Kenmore Dehumidifiers
Display for Krups Beertender stopped working
unplug the unit for 30 seconds, then plug back in. I had this problem, and it is a solution to most modern electronic devices. it reboots the system.
Jan 17, 2009 | Coffee Makers & Espresso Machines
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
156 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
