Question about Dryers
Fan only spins hi mode - Dryers
    Genius:
  • 1,617 Answers
Check the capacitor. If it's bubbling out it's bad.
Posted on Nov 21, 2013
Very loud when fan is running
This is likely caused by a faulty blower motor bearings, or the fan has something in it or it could possibly have broken. Shut down power to unit, remove cover and inspect the fan shaft, blades, and spin it. it should freely spin. If it hangs up you likely have a bad blower motor.
Mar 03, 2014 | Carrier XHB123D X/Y Series Heat/Cool Air...
Dell latitude e6400 fan not spinning
Is the laptop running hot? Sometimes the power saving mode in the BIOS will shut off the fan to conserve power when the processor isn't in danger of overheating. Try getting into the BIOS and playing with the fan and power saving settings to verify that the fan actually works as installed in your system. Otherwise, if you know that the fan works and you have it plugged into the system board correctly, there must be an electrical malfunction internally on the laptop and there is no way to troubleshoot further unless you know a lot about circuitry.
Jan 08, 2013 | Dell Computers & Internet
Hi ive got a hp g70-212em laptop that over heated, i shut it down as the fan was clogged and wasn't cooling it. i cleared the floof from the fan and it now spins freely again but the laptop will not...
1st try this.....discharge ur laptop battery then open safe mode and charge the battery full after that also discharge the battery in safe mode....if not works then there problem of fan..talk to service center
May 21, 2011 | Computers & Internet
Hi i have this problem the hifi works like normal but the fan does not spin
Fan will spin on high volume, increase volume and check does fan spin?
If still fan does not spin then it might be stuck or defective and unit will take apart to check fan.
Thanks.
Mar 27, 2011 | Sony MHC-RG290 Shelf System
Our window AC/heat unit fan only buzzes when turned on- no matter whether you turn on fan only or heat or cool mode.
so the fan does not spin and blow air? it could be a stick broken fan try free spinning it make sure its turned of. if fan spins freely its probably your start capacitor which is not to expensive.
Nov 10, 2010 | LG Heat cool Window Air Conditioner
My washer will not drain in test mode. It cycles back into the tub. Also it will not spin on any cycle.
Hi just read your posting.Does the machine drain the water at all?If the machine is recirculating the water in drain mode then your diverter must be stuck in the recirculate mode.Please look under the machine for me to the front right and you should see a red or black fan.This is your pump.Can you please reply to confirm the style of pump you have on your machine.If you do not have the pump with a fan attached to it then you have the newer type.The information on the style of pump you have will help me give you accurate information on how to rectify this fault.Looking forward to your reply.
Jul 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Turn on computer power up fan spins fast monitor
Here is some diagnostic information. The Fans running at full speed are an indication of a NO POST failure
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Apr 17, 2010 | Dell Inspiron 530 Desktop Computer
Fan on outside heat pump wouldn't spin put in new cap and started working when got off work it wasn't spinning again
I have a ruud gas pack, the blower fan wont come on. If we go out there we can spin it and she will run, but when the time shut off, so does the fan.. and it wont restart
Jan 28, 2010 | Ruud UBHC Air Conditioner
RV AC not working
With power off, go on roof & try spinning fan at rear through cover with a stick, or something, until fan has made 2 or 3 revolutions, then try fan mode only & see if it starts. If no luck, remove cover on roof (watch for bees & wasps) and spin fan good by hand a few times & try again, if no luck, replace fan start capacitor.
Aug 30, 2009 | Dometic Rooftop RV Air Conditioner
Outside compressor fan won't spin without a nudge
either you can lubricate it by spraying wd40 on the bushings. Although usually fan motors are permanently lubricated there are still dust particles that get through and cause it not to spin.
May 21, 2009 | Carrier 38CKC024 Air Conditioner
Dryers Logo
13 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
