SOURCE: How do you erase dictation
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
SOURCE: Dictaphone 425
The most likely cause is a broken headset cable. This item fails more often than any other part of the system.
SOURCE: unable to understand how to dictate and play back
It may seem too obvious, but make sure the volume control is turned up fully. If you do not hear a click through the loudspeaker when pressing the record button then either the 'speaker wire has broken or the 'speaker itself is dead. Parts are still available.
SOURCE: Dictaphone use for Medical Transcription
You'll need a digital recorder (Dictaphone makes one - a Walkabout Model 5220). Transferring a recording from an analog (tape) machine to a PC requires a patch cord to hook it up to your PC, then some sort of software to record it while it's playing back.
SOURCE: A cassette is dictated on, plays back fine on
Hello just set the speed switch on the front bottom left to 2.4
