Jumping print size
How do I set the sensitivity for the touch-pad to a lower setting?
    Sergeant:
  • 393 Answers
If there's a touchpad icon in the notification (tray) area on the lower right, it might have an option to lower the sensitivity. The Control Panel should supply an applet to the touchpad. The best answer is to get a mouse and disable the faulty touchpad.. the can be replaced too. Once a touchpad gets sensitive like that, the mere tapping on the keys of the keyboard can cause the pointer to move on you.
Posted on Nov 20, 2013
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
You cannot.
'jumping print size' does that mean your page is zooming in and out? you are doing the 'pinch-zoom' feature of most new touchpads using 2 fingers.
i recommend diasble the touchpad and use a regular mouse.
Mouse keeps jumping on dell latitude 410
Hi David,
If you are using touch-pad of your laptop try changing the sensitivity to lower in your touch-pad settings. If not; uninstall the touch-pad driver and re-install (or update) it, this will help if the driver is corrupted. OR try using a USB mouse and see this error occurs or not. If this jumping problem is not repeating then it will be the hardware problem of your laptop's touch-pad which a service technician can fix it. Thank you.
Please rate me if this solution was helpful for you!
Jun 23, 2011 | Dell Computers & Internet
Touch pad is way too sensitve and any hint of accidentally touching it send mouse and/or characters all over the place. Makes this computer very difficult to use.
Try these steps:
1. Go to the Control Panel and double click on Mouse
2. Go through the tabs in Mouse Properties window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, find the "Sensitivity" setting. Try changing this setting to lower the sensitivity of the touch pad to the degree you find acceptable.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
May 16, 2011 | Sony 4-660-223-01 Touchpad Keyboard
Over sensitive touch pad
Your sensitivity might be set to high. Go to Control Panel and find the mouse icon. You should be able to adjust your settings in there somewhere.
If thats not it and the cursor is jumping around a lot, to the point you can't control it, you may have a virus.
Dec 09, 2010 | Acer Computers & Internet
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
My Hp dv5 suddenly started giving problem when typing the cursor is jumping. what will be the reason? I cannot type continuously. I hav to search for the cursor where it goes. suddenly it disappears and...
This issue could be due to corrupt Touchpad drivers or corrupt Touchpad sensitivity settings or corrupt BIOS settings. To isolate this issue, please perform the steps provided below: 1. Uninstall and reinstall touchpad driver on the notebook. 2. Decrease the Touch Sensitivity of the Touchpad. If you are using Windows Vista on your notebook then you can follow the steps listed below for decreasing the touch sensitivity of the touchpad: a. Click Start and type ?Mouse? without quotes in Search field. b. Click on Mouse from the results list. c. This will open d. Click on Tapping tab in the Mouse Properties window. e. Click the Touch Sensitivity Button to launch Touchpad settings. f. Move the slider to the desired setting (in between Light touch to Hard touch) This will adjust the Touch sensitivity of the touch pad. Now check for the issue. 3. If the issue persists, then update BIOS on your notebook. To update BIOS, go to the HP drivers download page for your notebook model and then download and install the latest available BIOS update.
May 20, 2010 | HP Pavilion dv5000t Notebook
Compaq presario V3105TU touch pad not sensitive
Try goign into the touch pad settings and tunring the sensitivity way up. either by its software or goto the control panel and mouse settings. hope this helps in some way.
Dec 03, 2009 | Compaq Presario Notebook
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
Touch pad too sensitive, it always messes me up when I'm typing
You could try adjust the touchpad settings. Sometimes there is a touchpad icon in the taskbar that you can right click on to adjust the properties. You can also disable the pad and use a USB mouse instead.
Sep 11, 2009 | Sony 4-660-223-01 Touchpad Keyboard
My touchpad is too sensitive
1. Go to the "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
Nov 26, 2008 | GPX D1816 DVD Player
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
