Question about Roland Office Equipment & Supplies
Versa works media setting not responding to cutting
My konica bizhub 163 CAN'T ACCEPT PRINTER SIZE MODE AND GIVE ME MESSAGE-- NO SUITABLE PAPER
Incorrect media check to ensure the media is set for Metric I assume not inch for USA. Check your print driver for proper media settings metric versa inch
Sep 12, 2015 | Konica Office Equipment & Supplies
How do I set the tension on my JANOME 3434D serger?
Begin by setting all 4 dials on "3" which is the default setting on this model (often "5" on other machines). If a beginner, it would be best to thread the machine with four different colour threads according to the colours indicated on the tension dials (yellow, red, blue &green) so that it is easier to see how each thread responds as you adjust the dials. The two lower dials are for the loopers & must be adjusted until the upper & lower loops meet on the cut edge of the fabric - if below the edge: tighten the left dial & loosen the right dial (& visa-versa) just a fraction at a time. The two upper tension dials are for the needles: if too loose, loops form underneath the fabric below each needle, & if too tight the lower threads will show through to the upper side of your fabric where it is pierced by the needle. Good luck!
Jan 18, 2015 | Janome Sewing Machines
Ruud Heat Pump blows room temp on Heat and AC setting
A "Heat-Pump" is also known as a reverse cycle air conditioner, this means on heat the outdoor unit acts like the indoor section and vice versa. So in all probability you need to have it leak checked and recharged.
Apr 27, 2009 | Ruud UBHC Air Conditioner
My 3110 classic media player not responding
open music player.
mw_arrow.gif options mw_arrow.gif music library mw_arrow.gif update library mw_grin.gif job done mw_wink.gif
Jan 17, 2009 | Nokia 3110 Cellular Phone
Ipod shut off and wont do nothing
I took mine in today, its been doing the same thing for about the past month. Intermittently working. It will cut off and not respond for periods of time, then work normally, then cut off again. I took it to best buy, the geek squad "restored" it. And it did no good. It has done it twice since I was there this afternoon. Once for about 2 hours, and another time only about 15 minutes. --I'm not happy.--
Jan 12, 2009 | Apple iPod nano
Sansa e250 does not appear in Windows Media Player when connected
Go intothe Settings menu of the Sansa and change USB Mode from MTP mode to MSC mode or vice versa
Jan 11, 2009 | SanDisk Sansa e250 MP3 Player
TV Tuner not tuning
G´day m8,
you have to set the security on the laptop as you have set it on ther router, and this is, at the same time, your problem with tuning the TV card, as it has no connetion to the internet....
plz let me know if this FixYa. regards /Teis
Jan 11, 2009 | Computers & Internet
Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Dec 06, 2007 | Canon iPF700 InkJet Printer
Top Roland Office Equipment & Supplies Experts
Michael Harrier
Randolph Tidwell
David Payne
David Payne
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
