Question about Electrical Supplies
Lombardini im 350 - Electrical Supplies
Cant rotate the screen on my emachine 350
please select your product from the listbelow:
http://support.gateway.com/us/en/emac/default.aspx
after that download the graphic driver
Feb 14, 2014 | Acer eMachines 350-2074 Netbook
Spark plug gap
the spark plug gap for gmc sierra with the 350 ci 5.7 is 0.35 Im not sure what it is for the other motors but if you have a 350 in a 1993 sierra its 0.35 I know this is correct because its on the sticker under my hood and im changing my oil right now so I just read it about 20 seconds ago....
Jul 31, 2013 | 1993 GMC Sierra
Lombardini 6LD435 Gen Air filter where can I get one
I would go to the fine cars ask for advise .
Jan 30, 2013 | Cars & Trucks
Can i put a 350 in my 1989 chevy c1500 with a 4.3 v-6?
YES 350 will work but get pcm & harness from 350
Sep 05, 2012 | 1989 Chevrolet C1500
Need user manual mfor Lombardini 6LD435/B1
here is a link for the the 2 manuals there is 2 similar engines yours should be the first one, as you may know the company is in Italy but they have distributors in the US here is their website
If it works for you, don't forget to rate me
thx
May 26, 2010 | Electrical Supplies
Hello i have a 1972 honda 350 four and im trying to remove the carbs what parts do i need to remove proir to removing the carbs
fuel tank
side covers
loosen air box mount bolts
throttle cables
manifold clamps
spray some lube to help
Apr 08, 2010 | 1972 Honda CB 350 F0
Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Oct 19, 2009 | Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
