Question about CardioVision Televison & Video
No sound when i plug headphones into CardioVision
When I plug headphones into CardioVision pad there is no sound coming through headphones. I have tried different headphones to make sure that was not the problem. Thanks!
4 Suggested Answers
SOURCE: Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Posted on Dec 27, 2008
  • 5 Answers
SOURCE: Sony Bravia 40
go to your remote contol ( menu )
then you go to the option set up.
then you go to headphones and you can set the volume louder.
You will see that it works fine.
Greetings from Holland Gesinus
Posted on Aug 15, 2010
jdvillanueva
  • 2098 Answers
SOURCE: headphones won't work. I
Hi pmcgonigal,
This fault indicate of two reasons :
Bad solder joints in the earphone jack. Check and make some re-soldering in this parts.
Faulty earphone jack itself. If the solder joints is good, replace this jack and your unit will have a sound output in your headset again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 21, 2011
Headphone problem
Ensure you are not plugging into the microphone input.
Dec 17, 2015 | Computers & Internet
I have a RMP-5 Rhythm Coach. I cannot get any sound from the pad when I practice. Help
Hi, after doing a bit of googling it occurs to me that the internal speaker is ONLY for the metronome / click & not for the drum sounds themselves. You will need headphones or some external audio gear like your hi-fi system or oth r amp & speaker. I found this "The pad has 54 sounds in it (covering all parts of the drum kit but mostly snares), which are triggered when you hit the mesh head, but these can only be heard over headphones. The built in speaker is only used by the metronome sound (when there are no headphones attached) and then it only has a beep sound attached to it. However, plug in headphones and you get a variety of available click sounds including a proper ticking clockwork metronome." Hope that helps a little? Good Luck :-)
Dec 07, 2014 | Roland RMP-5 Rhythm Coach
When I plugin my headphones The sound dosn't go to the headphones.
First, try plugging in different headphones. If those work, then your headphones are broken and you need to replace them.
If those don't work, then please check to make sure you're not plugging them into the microphone jack - you'll see two identical plugs, usually the headphone one is marked with a pair of headphones.
If you're plugging known working headphones into the correct port, then your computer must logically be the broken thing.
Dec 20, 2013 | Motorola Mobility S9 Headphones
Headphones plugged in but sound still comes from speakers no sound from headphones
Going by the description of the issue, I suspect that the headphones are not plugged into the correct jack.
Please check once and plug in the headphones to the black/lime green jack which has the headphone icon on it.
Sep 06, 2010 | Computers & Internet
I believe that the line going into the headphone is broken
Does it come and go the sound when you move the cable? If so then yes it is. Make certain it's not at the plug end first. It's easier to replace the plug then the whole cable. If in doubt cut of the plug and replace it with a new one. You will have to solder the old cable on to it.
If it doesn't solve the problem or you know for certain the plug end is good. Then you will have to remove the cable at the earphone. First remove the ear pad cushion and any felt, from the one where the cable goes. This should reveal access screws. Unscrew them and remove the cable. You should be able to get a new cable from your local hi-fi/electrical shop.
PS You can glue the felt back on if you have to force it off.
Jan 01, 2010 | Bose On-Ear Headphones
Hi, could you please provides a circuitry diagram for PXC250.My headPhone was broken, i'm gonna to fix it.cheers!
Looking at them from the picture provided by FixYa, I rather think there's no circuitry involved! It looks like the wires go into two speakers. As you don't say what the fault is then I will guess a few things for you and some solutions.
1 One side dead - fault in plug or cable or speaker.
2 Cutting out - faulty cable or plug.
3 No sound - faulty cable or plug.
If you need to get to the speaker, remove the pad, remove foam (force it if it won't come off, glue on when finished). You should see screws then.
You should be able to get a new cable/plug from any good electrical parts shop such as Maplin or RadioShack. You will probably need to contact the maker for a new speaker.
Dec 16, 2009 | Sennheiser PXC 250 Consumer Headphones
The pads are teaard and Yellow Sponge of the pads came out,
Based on what you are saying, those are the signs of old age, unless the dog got them..
Short term solution is to put the foam back in as best u can, and either glue or duct tape the covering back in place.
If you use the duct tape, be sure to not to cover the area where the sound comes from when you repair them.
The duct tape will not affect the comfort factor if applied smoothly and wrinkle free,
Long term solution is to replace the ones you have.
Check around for pricing.
If your sound equipment is fairly new, wireless headphones are an option.
Happy listening.
Sep 30, 2009 | Bose QuietComfort 2 Consumer Headphones
When using microphone sound also come from laptop sound on compaq
Leave headphone plugged in and restart the laptop with headphone jack plugged.
Unplug jack and restart again with no jack plugged.
This is a Compaq factory defect.
Apr 18, 2009 | Compaq Computers & Internet
Got no sound from the right earphone of my MDR-v500 headphones
It's actually quite easy to open up ... the pad just slips off, and its really easy to get back on and there is a set of three small t screws underneath that just need unscrewing and then you're inside
Jan 27, 2008 | Sony MDR-V500 Professional Headphones
Televison & Video Logo
Top CardioVision Televison & Video Experts
Electro Med Services...
Are you a CardioVision Televison and Video Expert? Answer questions, earn points and help others
