Question about Car Audio & Video
I have a Becker 2660 CD Changer. When I load the magazine and insert it into the changer, I hear the disk load. The PCM says Disk 1 Track 1 play. No sound. The disk plays for about 15 to 20 seconds then the next disk loads. The Nav system says Disk 2 Track 1 Play. No audio. This happens for 15 to 20 seconds and then the cycle repeats for all disks in the magazine.
melnavz
  • 1226 Answers
SOURCE: 2003 Lincoln LS
hello!
That is the problem of cds changer today. However, maybe that could be resolve by severe examination in where is the source of the problem. some causes made by dust inside, just blow it by a blower, wrong position of the tray, the alignment should be fix, Power off the and disconnect power for almost a minute and hooked it back ..Hope you should be ok.
fixya melnavz
Posted on Feb 29, 2008
Lexdiamonzz
  • 203 Answers
SOURCE: jvc ch-x350 12 disc cd changer. Loads cd but will not play
If you are inserting non original cds, cds you make from your pc or cd copies sometimes they dont read, another reason is to make sure that you are inserting the disk with the correct side up, it will show you in the cd changer magazine slots. If none of this solves your problem then you have a defective cd mechanism and you need to replace or repair the changer. Very common problem with JVC Cd Changers, I used to replace them all the time and they tend to skip alot as well, get yourself a Pioneer if money is ok if not then follow my steps.
Good luck and dont forget to rate and vote for me if I helped you.
Thanks.
Posted on Jun 13, 2010
SOURCE: sony cdx-t69 CD Changer Unit
Bought a toyota with sony cd changer and had magazine stuck. Disconnected the cables at the back and left for 5 min. Hooked it back up switched to acc and pressed the eject button and came straight out. Didnt need to reset radio and retune.Now works fine.
Posted on Jul 01, 2010
kenw392
  • 2226 Answers
SOURCE: How do you load the magazine on a VW Beetle six
make sure the cds are not loaded upside down.
Posted on Feb 11, 2011
SOURCE: '03 Honda Accord 6 disk changer won't load/eject
take the cd/player out of you dash board . Facing the stereo ,on your top upper right hand side ,one of the gear is fell off , break or is slipping from the shaft. that's why you can not load or eject your cd. This gear is driving the cd door and rollers. If the gear still in tack , all you need is a drop supper glue on the shaft and wait for it dry.
Posted on Nov 27, 2012
I got a vw golf 1.6 s yesterday n cd player keeps saying CHK MAGAZINE or no disc I've looked online n said something bout a changer but there is no changer any ideas what it could b what to do?
some cars use a cd magazine situated under a seat or in the boot. if the read out states check the magazine then there probably is one
talk with a service dealer to find the location if it has one.
May 05, 2015 | Car Audio & Video
Jvc ch-x350 12 disc cd changer. Loads cd but will not play it. reads: no disc and moves to the next cd and repeats. ??
Thanks.
Jun 13, 2010 | JVC CH-X350 12-Disc CD Changer
I want to buy a Becker 2630 CD Magazine
Becker 2630 CD multichanger with 10 cd magazine 100 euro: messenger id: mojo_bf or tel: 40723730633
Mar 24, 2010 | Becker Silverstone 7860 6-Disc CD Changer
Cd won't go in the changer.
you might want to try replacing the cd magazine. and if that doesnt work it's going to come down to you replacing the cd changer itself
Feb 16, 2010 | Car Audio & Video
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Error Message
sounds like the lens is dirty -try this out you kow them cans of stuff they use to clean keyboards with its like filtered air or something -try to blow out the guts of the cd changer with one of them cans and maybe it will help with functionality do the same with the cartridge emtied out and then run a cd lens cleaner disc and see if that does the trick-
May 21, 2009 | Kenwood KDC-C669 6-Disc CD Changer
CDC-3 magazine will not eject nor play, error on receiver indicates magazine error
1998 porchea boxter cdc-3 cd changer, The cd changer keeps on changing tracks as if their are no cd's in the changer. keeps going from 1 to 6 and then changes to radio.
May 19, 2009 | Becker Car Audio & Video
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
