Question about Kitchen Appliances - Others
Popcorn agitator broken - Kitchen Appliances - Others
    Champion:
  • 252 Answers
Duplicate
Posted on Nov 23, 2013
The Kettle Agitator gets stuck. Appears the Rotating Center is Wobbly. . .
The motor output shaft bushing might have came loose I have seen where it falls out of the motor and the shaft becomes real wobbly and it will cause excessive wear in the kettle cross bar bushing too. also make sure the cross bar and lid assy. is not come loose from the kettle.
Feb 27, 2016 | Star Manufacturing Star G12-Y - Galaxy...
Agitator has come out of popcorn machine
if you have a gold medal popper, there is a weight on the shaft the sits over the middle hump of the stir wire. you must take the lid asembly off of the kettle to get the stir wire back in.
they do not fall out without some thing else wrong, check if the shaft is broken under neath the weight.
Nov 20, 2013 | Gold Medal Kitchen Appliances - Others
When turning agitator on it gets jammed in the spur gear.
This is a hard symptom to troubleshoot, it can have many different causes.
1. Is the stire wire in the kettle straight and spinning freely?
2. Does the agitator shaft spin freely in the crossbar?
3. Is there a small needle bearing on top of the spur gear attached to the kettle? it is a small metal circle that spins independently of the agitator shaft located ontop of the kettle spur gear, it can fall off.
4. The plastic block in the cabinet roof that has the motor spur gear coming out of it, is it cracked?
5. Does the motor turn when the switch is turned on with the kettle in the dump position?
All of these can lead to an answer of why the agitator stops turning while popping.
Sep 06, 2013 | Gold Medal 2656 Ultra Popcorn Maker
How do I get the agitator rotate
The motor in the top of the machine should rotate the gear sticking out of the top of the cabinet when you turn the switch on. This gear should connect with a gear on the top of the shaft that sticks out of the kettle when the kettle is in the correct upright position and turning the stir rod.
Make sure the kettle is installed correctly, and the switch is in the on position. If the motor is not turning with the switch on, it is broken and should be returned to store if possible.
There are no repair parts for this brand popper, and they cannot be repaired.
Sep 03, 2013 | Nostalgia Electrics Helman Group CCP-510...
Galaxy popper popcorn machine has a stripped gear in the agitator can I buy just the gear or can I buy gear box model # g8
You will need to buy the entire agitator motor. For a G8 that is part number y8213. You can get it at a Concessions dealer, or from Partstown.com
Apr 11, 2013 | Kitchen Appliances - Others
When I plug in my gold rush gr6 popcorn maker, it seems to not have any power at all. No light, no heat, no agitating. I am sure the outlet is working. What should I do?
Try calling their tech support at: 773-433-7450 or try finding a local dealer at: http://www.cretors.com/dealers.asp Have your serial number ready.
Dec 08, 2010 | Cretors Goldrush Popcorn Maker
The light and agitator switches don't work anymore unless the heat switch is on, they used to work individually, any help?
Try calling their tech support at: 773-433-7450 or Try finding a local dealer at:
Nov 17, 2009 | Cretors Goldrush Popcorn Maker
Popcorn maker
When Popper Has Popped Corn Just Before.
1. Pour the properly measure amount of Oil into the kettle.
2. Wait about 45 seconds - or until the Oil in the kettle starts to smoke slightly.
3. Pour the contents of the properly measured corn cup (kernels plus popcorn salt or Flavacol) into the kettle.
4. Wait about 2 1/2 minutes. If you are using a pan on the stove without an agitator, you must constantly shake gently. When the crackling noise of the popping corn is no longer heard, dump the kettle and empty it completely.
5. Repeat if needed for more popcorn.
6. When you are finished popping, turn off the kettle agitator switch (if you have one) and turn off the Pilot light/ heat switch.
7. After the machine has cooled enough so as not to be dangerously hot, wipe the outside of the kettle with a soft damp cloth. This helps prevent a heavy build-up of the Oil.
TIPS
- Bagged floss keeps a day or two, depending on the humidity
- Use bags to make and display cotton candy in advance - use cones for immediate sales
- Unless you're experienced, it's best to turn off the motor to refill the spinner head
- If machine will be used more than 20ft. from power source, be sure to have an adequate extension cord
Nov 18, 2007 | West Bend 01568 Popcorn Maker
Kitchen Appliances - Others Logo
83 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
