Question about Brother XL-5130 Mechanical Sewing Machine
The presser foot on the brother xl-5130 has fallen off
I have a model of the Brother XL-5130 sewing machine from 1963. As I was sewing with it the piece that holds the needle up and a hook that must help somehow has fallen off. I figured out how they fit back together, but they just fall apart again once I resume sewing. Is there a way to fix this without purchasing a whole new part?
  • 397 Answers
Please send me a picture and I will gladly assist you with all the help you may need ;)
Posted on Feb 28, 2014
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
  • 2976 Answers
SOURCE: i have a brother xl
There is a small screw on the bobbin holder. Tighten it SLIGHTLY. This will increase the bobbin tension.
Posted on Jan 02, 2009
make sure that when you insert the thread *top hole bottom to top* that you turn the bobbin itself until you hear a click *that is the spring sliding into the ****.
Posted on May 02, 2009
SOURCE: Brother XL-2220 ND Sewing Machine.
got a machine handed down to me from my grandmother but she didn't teach me how to thread it. can some one please help me?
Posted on Jul 25, 2009
SOURCE: brother sewing machine model XL-6562.needle holder came off rod.n
The needle holder has a screw right above the screw that holds the needle in place. It really doesn't look like a screw because it does not appear to have a slot for a screwdriver. However, with a small flat head screw driver you can tighten it up. There is also a curverd wire that must be inserted into a slot at the bottom of the holder. The screw tightens against the wire that tightens against the post. (It's a curved wire that curves around the front part).
Posted on Aug 20, 2009
The ankle on my machine has unfortunately fallen off during a move, and I can't for the life of me get the internet to help me find a new one. HELP.
I am not too sure of what you mean by the ankle, do you mean the part that holds the foot on? That is called a presser foot holder, that only screws on. You can call Brother at 1-877-276-8437 and order from them or go to www.sewingpartsonline.com and order that part plus 10 attachments for $24.50 that is a pretty good deal actually, because yours didn't come with many extra feet. If, you decide to do that search for "presser foot holder" and the click Brother, but you have a low shank and Singer will also work. Good luck
Apr 20, 2011 | Brother XL-5130 Mechanical Sewing Machine
The little thing that the needle goes into broke. How can i get a new one and what is it called? I have a Brothers machine XL 5130
it's called a needle clamp-check sewingpartsonline.com
on the left hand side click on brother parts
go down till you find your model number there is a brother xl 5130
it's close to the bottom of the page
please rate this with the thumbs in upper right hand corner
Aug 09, 2010 | Brother XL-5130 Mechanical Sewing Machine
Brother XL-5130 machine...cannot get it to darn or embroidery work. I covered feed dogs with the plastic cover but cannot find a lever to put down the feet. With presser foot lever down (no feet and not...
You probably do not have lever to put the feed dogs down. That's why you have a cover. To free style embroider or darn you don't need a foot but the presser foot has to be down and as you run the machine, YOU will be doing the stitching by moving your fabric back and forth. This is usually done with a wooden embroidery hoop so that your fabric stays taught. I have done it on jeans without a hoop. Hope this helps.
May 18, 2010 | Brother XL-5130 Mechanical Sewing Machine
Thread is catching & breaking somewhere inside the machine before it gets to the needle. brother XL-5600 machine
According to page 18 of the manual, the only place the thread could be catching would be the tension discs or the uptake lever.
Lift the presser foot and run a heavier thread or flat, unwaxed dental floss through the threading procedure to see if this will clean out a thread that may have jammed into the discs.
Always thread with the presser foot up and make sure the uptake lever catches the thread.
If this continues, take the machine to an authorized Brother dealer for service.
Apr 10, 2010 | Brother XL-5600 Mechanical Sewing Machine
Does the Brother XL-5340 do an overlock stitch? If it does do I need to change the foot and to which foot? Thanks
There is an overedge stitch (page 38) that uses the regular presser foot.
If you do not have a manual, you can download (free) from the Brother site.
http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL5340
Mar 31, 2010 | Brother XL-5340 Mechanical Sewing Machine
The lever on my sewing machine the one you use that lifts up the presser feet is jammed. what do i do?!
Put some WD40 on top of the presser bar and leave it overnight, undo the pressure on the presser foot if you can by the dial or screw on top, then work the lever up and down
Mar 22, 2010 | Brother XL-5130 Mechanical Sewing Machine
Presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Nov 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Apr 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
54 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
