I need a wiring schematic for Behringer GMX 112.
It seems that schematics for Behringer amps are hard to find. If you have a GMX 112 schematic or schematic for any of the Behringer GMX series, I would be thankful :)
  • aviocreep
    aviocreep Nov 22, 2013
    I have finally found a GMX-series schematic. It is a GMX212 schematic but I think GMX112 is similar (it has two digital effects circuits instead of one). It is described as GMX1200H but on the diagrams, it's said that they apply to GMX212. Here's the link:
    GMX 212 schematic
5 Suggested Answers
max98372
  • 68 Answers
SOURCE: i need the Nokia N-Series Schematic Diagram
http://ucables.com/b2b/support/index.htm
it will helpfull for you
good luck
don't forgot vote me
Posted on Dec 19, 2008
iadame
  • 676 Answers
SOURCE: i need schematics for wiring ,colors etc..
Red 12 volt switched
yellow 12 volt constant
black ground
white left front +
white/black left front -
gray right front +
gray/black right front -
green left rear +
green/black left rear -
purple right rear +
purple/black right rear -
if you need more information or there are more wires please feel free to send me a message. Please rate.
Posted on Nov 17, 2009
  • 5603 Answers
SOURCE: I have a behringer bx4500h.
Behinger normally doesn't give schematics... However here is a link to a BX1200 schematic at a foreign site. OFTEN they use the same circuitry within a series of equipment.
http://elektrotanya.com/behringer_bx1200_sch.zip/download.html
Note it is a zipped file of both F and H revisions.
Please note that the symptoms you describe are NOT usually something you will find in the preamp, but rather in the interconnections. It appears that the BX1200 uses TRS inputs at the jacks... not sure what your BX4500 does...
Make sure ALL your interconnected equipment is powered from the SAME receptacle to avoid ground loops and hum. Use balanced lines everywhere possible.
Posted on Dec 07, 2010
  • 6468 Answers
SOURCE: Cub Cadet 2150 ignition problems. Need a wiring diagram to source problem.
don't have a diagram but i would check the safety switches jump them while looking for the bad one with a paper clip
Posted on Apr 13, 2012
I'm Ziro. I need a part list for the main power supply board for behringer pmp4000 mixer, two transistors were removed from it and I need to know the part numbers of each in order to install them.
In my opinion, due to the physical appearance of pmp4000 and pmp3000 look the same, it will most likely also have a common circuit and parts list (at least, most).
Usually Behringer (and all the manufacturers), with the same series / sequence, using the same circuit, the difference is the number of channels only. You can compare the parts list on PMP3000 schematic, with your PMP4000.
PMP4000.
PMP3000
You can download from this link.
http://elektrotanya.com/behringer_pmp3000_sch.rar/download.html
Hope this helps.
Regards.
Oct 05, 2015 | Behringer Music
Where can I get a schematic for the output section of the mixer on a behringer 1280s?
No hope. I have replied to this sort of question elsewhere but Behringer are very protective of their stuff and won't even let us have diagrams. Only Behringer service. If anyone has any Behringer service manuals / schematics we would love them
Oct 31, 2013 | Behringer B3031A 2-Way Active Studio...
Need schematics for europower pmp518m
Hello
I've with me the schematics for Behringer Europower PMP-3000 -PMP 1280 & PMH 518. If any one will suit for your set, inform me. OK.
Dec 28, 2011 | Audio Players & Recorders
Behringer sx3242fx not working .i need circuit diagram .
Behringer will not release schematics unless you are an authorized service agent... however, sometimes you can make do with the few schematics floating around... What is the problem with the unit? They typically use a switching power supply and the schematics of those aree usually similar enough to repair them.
Sep 09, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
The compression speaker does not work
Here is your schematic for the power amp. There is a separate amp for the tweeter using a LM3886 which is fairly well protected. Open the unit and test the tweeter driver.
http://elektrotanya.com/behringer_b215a_power-amps_psu_sch.pdf/download.html
Scroll down to "Get Manual" and click on it to download the schematic. At the site is also the preamp section as a separate schematic. You probably don't need that for the failure you are seeing. A lot of the tweeter drivers seem to get blown up, but once you test you will be able to find if the problem is in the amp or the driver.
May 03, 2011 | Behringer B215D Powered Speaker (550 Watts...
I need a service manual with a circuit diagramme to repair one of these with an input circuit fault.
GO ONLINE AND CHECK BEHRINGER EUROPOWER EXP3000 STEREO POWER AMP. YOU MAY GET SOME HELP THERE.
Mar 23, 2011 | Behringer EUROPOWER EPX3000 Stereo Power...
Where can i get a behringer b2031a schematic
i found legit looking schematics here...the pdf includes many revisions, adding to their credibility...haven't put them to the test...
http://www.electronica-pt.com/index.php/component/option,com_remository/Itemid,34/func,startdown/id,16026/
Feb 14, 2011 | Behringer B3031A 2-Way Active Studio...
I have a behringer bx4500h. pre-amp board has a noticeable hum that also reacts to tone controls. I need a schematic to fix it. Can you direct me to a schematic of this unit?
Dec 07, 2010 | Behringer Bx4500h Ultrabass 450w Bass...
My EP2500 died, the capacitors are swollen on the top in the power supply.
Unless you are a qualified audio service technician, you should refer repair of this unit to an authorized Behringer service depot. The capacitors you refer to can store lethal amounts of electrical charge. Also, Behringer service manuals and schematics are notoriously difficult to get.
Oct 07, 2010 | Behringer EUROPOWER EP2500 Amplifier
Hello; I have a used Behringer pmp5000 mixer. The
Without knowing how you have your monitors configured it is hard to analyze what you have posted.
In brief, SW3 on the schematic that selects MAIN L and MAIN R in the upper position, MAIN and MONITOR in the middle, and bridged in the lower is used to configure the internal amps.
In the upper position, the amp power outputs come from the mixed stereo bus and are simultaneously controlled as a stereo signal by the MAIN slider.
In the middle position MAIN and MONITOR, the left amp receives the signal from the mix bus and is controlled by the MAIN slider. The MONITOR output from the other side of the power amp is controlled ONLY by possibly the "MONO" slider.
The schematics are hard to decode and what is needed is a signal flow diagram.
For my uses, I don't try to use splitting the power amps between mains and monitor but prefer to use the mains together with SW3 in the upper position (Note your 27 may be refering to the user manual designation for same switch). I then use another small amp from the 1/4 inch MONITOR jacks whcih are under control of the MONITOR sliders.
Please note that the MIX for these two MONITOR channels is controlled by the MON1 and MON2 knobs for each channel.
May 23, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
 Grubhead
Grubhead
