Question about Verbatim VER95327 USB Hard Drive
Usb flash disk with write protected
My flash disk cannot open my files on it. with write protected as an error message. What do do read files sir? thanks. Oko
  • eknath Nov 02, 2007
    1 . when i copy file from hard disk to pen drive the error is write protected
    2. when format the pen drive error is write protecteddisk
  • Anonymous Sep 03, 2008
    not displaying box to choose to open files etc
    President:
  • 1,257 Answers
First try to see is there any lock in your drive and see if its not locking it, you will see a switch which locks the device at one side and unlocks it when you slide that swiche to other side ,some drives comes with that option to protect it ..but if it is not
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 13, 2008
  • 84 Answers
Does it have a write protect tab/switch? all you have to do is flip that :D
Posted on Oct 08, 2007
SOURCE:
SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive now tells me that it is a read only file. I copied a file and renamed it. Now when I do new work I get a message that tells me I have a read only disc or
Open a command prompt and remove all file bits.Windows Button > type CMD and press enter.
  • CD <drive letter:\> press enter
  • attrib -R -A -H -S <file path\file name>
This will clear the read-only bit, archive, system and hidden bits.
Also right click the file and go to security and make sure you have write permission to the file.
Also verify this flash drive doesn't have a physical write protect switch
Jan 31, 2013 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My Memorex USB flash drive is write protected
t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
Note: your files will be erased if you format your flash drive.
If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Jan 27, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Usb flash drive problem
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 11, 2008 | iLO (2 GB) MP3 Player
ReadyBoost Error
In the future, always use the Safe Removal method before removing a USB drive. This prevents this kind of error in the first place.
If you haven't done so already, reboot, then insert the USB. Make sure there are no windows open which reference the USB device. Then use Safe Removal (right click in the lower right hand corner of the task bar. That should clear it.
If that doesn't work, right click the USB drive in My Computer, choose Properties. See if you can clear the Read Only setting.
Last resort - copy off the files you need from the USB, and format it.
Jul 17, 2008 | Computers & Internet
Verbatim VER95327 USB Hard Drive Logo
667 people viewed this question
Top Verbatim Computers & Internet Experts
gggg
Don Hart
Duncan Mutch
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
