Question about OKI C9600hdn Laser Printer
OKI C9600 service call fatal error 220 - OKI C9600hdn Laser Printer
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
  • 97 Answers
SOURCE: OKI C3530 MFP
Looks like a fuser problem.
Re-saet the fuser.
Check for pieces of paper, etc. in the path.
Service call 155: Error
Defective fuse
cutting of fuser
Is the fuser installed correctly?
Does the error recur?
Yes
Reinstall the fuser after its
connection connector is cleaned
Turn on the power supply again
If error still exists_
Replace M32 board after check
the cable connection.
Posted on Dec 07, 2008
  • 78 Answers
SOURCE: fatal error 917 on an Oki C9600 printer
A fatal error 917 means there is a problem regarding the belt **** sensor.
Usually it means the printer can't see the transfer belt rotating.
First thing to try is to remove and re install the transfer belt, if that does not work you should replace the transfer belt.
Posted on Jan 07, 2009
  • 526 Answers
SOURCE: fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Posted on Aug 28, 2009
Testimonial: "Thanks for the advice SALES320 in that it ended up being a issue with the yellow drum unit."
  • 97 Answers
SOURCE: oki c9600 fatal error 175
Error 175
Fuser Thermistor
short-circuit or Open
is detected (High
Temperature (HOT)
or Low Temperature
(COLD))
Turn ON power again.
Leave in that state for 30
minutes then turn ON power
again.
Posted on Mar 29, 2010
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
My Oki C9600 Printer showed an error message, Reset Drum Basket - Waste Toner Transfer Error. After removing and replacing the toners, drum and waste toner bottle a new message appeared, 940: Fatal Error....
940: Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Dec 21, 2009 | OKI C9600hdn Laser Printer
Oki c9600 fatal error 175 ?
Error 175
Fuser Thermistor
is detected (High
Temperature (HOT)
or Low Temperature
(COLD))
again.
Dec 06, 2009 | OKI C9600n Led Printer
Fatal error : 144 on a Okidata
Aug 28, 2009 | OKI C9600hdn Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Fatal error 917 on an Oki C9600 printer. What does this mean and how can I resolve the problem. Many thanks James
Jan 07, 2009 | OKI C9600hdn Laser Printer
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
OKI C9600hdn Laser Printer Logo
46 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
