Question about Hyundai ImageQuest HQL320WR 32 in. HD-Ready LCD Television
Hyundai N91S monitor need color code for vga cable male connector
SN N91SPAB063V05087-wire broke at male vga connector, have replacement connector need wire color diagram to connect to correct pins.
motor1258
  • 6674 Answers
SOURCE: 2002 Sonata TPS wiring scheme
Try here, you may have to search a bit but, ..
( http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280194b55 )
Posted on Dec 20, 2008
alicantecoli
  • 22326 Answers
SOURCE: radio wires cut in my car need code and or diagram for jvc-r300
this is easy to do and you musnt be scared.first find 12v permanent ,then 12v switchable,ground ,ignore electric aerial which is normally blue or yellow use a piece of twin flex connected to battery and flash speakers so you know which is where,good clue is speakers have same coloured wires but one has a black or white flash through it .And away you go music
Posted on Feb 01, 2009
alicantecoli
  • 22326 Answers
SOURCE: Color code for radio wires in Hyundai Sonata 2004?
look for the thickness of the wires ,or better still buy a ready made connector block that connects to the existing factory wiring
Posted on Sep 20, 2009
emissionwiz
  • 79186 Answers
SOURCE: Im trying to connect my pioneer radio to my
Radio Constant Wire 12V+: Red
Radio Ignition Switched Wire 12V+: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Pink/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Factory Amplifier Turn On Wire: n/a
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Black
Right Front Speaker Wire (-): Yellow
Left Rear Speaker Wire (+): Blue
Left Rear Speaker Wire (-): Red
Right Rear Speaker Wire (+): Green
Right Rear Speaker Wire (-): Orange
Posted on Oct 06, 2009
ghost45
  • 1280 Answers
SOURCE: need a wiring diagram for Hyundai Sonat 2002
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Posted on Oct 18, 2009
Missing adapter or plug in connection to 15 balance mointor model 2015
The Balance CM2015 monitor uses a VGA connector,
http://www.ebay.com/ctg/Balance-CM2015-15-LCD-Monitor-Black-/52125929
(The above is for reference only. Not advertising)
A VGA connector is also referred to as a 15-pin D-Sub connector,
http://en.wikipedia.org/wiki/VGA_connector
This is information on a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If this is the monitor cable you have, you need this type of adapter,
http://www.directron.com/dviadapter.html
Now LOOK closely.
This adapter has male pins that stick out, and go into a female VGA connector on the monitor. The DVI side of this adapter has socket holes, for a male DVI cable.
IF, your monitor has a male VGA connector on it, and the DVI cable you have has socket holes, you need this adapter,
http://www.directron.com/dvitovga.html
If your monitor cable is not a DVI cable, post back with the style it is.
If nothing else post how many pins are in the connector on the cable, and how they are arranged.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 27, 2012 | Computers & Internet
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
More information on the DVI connector styles, and the Digital Visual Interface technology,
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
I don't see any connection to hook up speakers
the vga monitor cable also carries the audio - there is a 3.5mm jack on one end of the cable that plugs into your speaker socket
Apr 16, 2011 | Hyundai Electronics ImageQuest N91S 19"...
The Envision H170L Monitor VGA cable.
the Envision H170L Monitor uses an interface 1.0x VGA - 15 pin HD D-Sub (HD-15). The same VGA cable wildly use in different computer brands..I was wondering why you have not found a replace for that cable. It can be purchase from any computer store.
If you are planning on cutting the wires and solder it together that would be easy if you have the diagrams of the pin numbering for male VGA connector and the female VGA connector. Check first this diagrams and follow strictly the coding of the wire so that it would be successful when connecting it together.
It is also better if after you solder the wire, you will use an shrinkable tube on the connection. Cover the whole sections of interconnected wires with shrinkable tube before you use the vga cable.
Jun 03, 2010 | Envision H170L Monitor
Need Cable Connector for VA902b monitor
Any PC repair shop should have this standard VGA DB15HD cable. Or just go online, it is just VGA CABLE 15-PIN/3-ROW male to male.
Apr 05, 2010 | ViewSonic VA902b 19" Monitor
How do I find and replace the vga cable? (It is hardwired to the back of the monitor.)
I got hold of an old vga cable (15 pin), cut off the male end. I then cut the existing cable comming out of the monitor. After soldering the wires together and lots of electrical tape wala - it works.
Now the problems I incured - Don't solder wires together based on color, they probably will not match. Peel back the ends of the cut off connectors and find each pin with a Multimeter. Once you find each wires match solder them carefully and tape. When done test and if good place a short splint on the spliced area and tape. This will keep the wires from breaking from movement. Good luck.
May 24, 2009 | Sylvania SF150 15" Flat Panel LCD Monitor
Hyundai Monitor Starts up with pink shade color than goes normal
It may be the inverter and it can also be your speakers, if they are kept close to your monitor.
May 13, 2009 | Hyundai Electronics ImageQuest N91S 19"...
Vga cable and power cord for monitor
The vga cable is a DB15, 3 ranks with male connector at each end,
(you can use a vga extention and add a little male to male adaptor at the female end to get finaly 2 males connectors)
And, the power cord is in fact an ac/dc adaptor, the replacement part is: 12b27-0428 (12v 5A 60w 4 pins) ...
just type de number 12b27-0428 on internet and you're on ...
Mar 12, 2009 | ViewSonic VG900b 19" LCD Monitor
VGA Cable Wire Colors
I don't think and RGB cable will work with a VGA cable because the signal in the video card is completely different. It's not just the picture but the scaning and refresh rates are totally different. Even if you could wire one it probably won't produce a picture.
Jun 30, 2008 | HP Compaq FS7600 17" CRT Monitor
Monitor Hyundai N91S
please reinstall your motherboard cd once again if not upgrade your graphics card...
Dec 31, 2007 | Hyundai Electronics ImageQuest N91S 19"...
Hyundai ImageQuest HQL320WR 32 in. HD-Ready LCD Television Logo
26 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
