Question about Copystar CS-1500 Copier
C-7 990 ERROR CODE - Copystar CS-1500 Copier
2 Suggested Answers
  • 143 Answers
SOURCE: c-7 990 error code
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine board
Posted on Aug 19, 2009
My ricoh aficio code a 990 how to fix them ?
An SC990 is usually an error indicating maintenance is overdue. The only way to verify that is by printing out the SMC report and seeing the subcodes. In the case of this model when is the last time the drum and developer was replaced?
Nov 15, 2014 | Ricoh Aficio 1015 All-In-One Laser Printer
Oki c321dn 'service call 990:error'
Error 990 refers to the toner capture sensor unit, that black knob looking thing on the toner cartridge itself. I'm betting the error popped up right after changing the toner cartridge?..... therefore, it's a defective toner cartridge.
Aug 14, 2014 | Office Equipment & Supplies
Canon 5180 error E000350-0000
Error code 990 indicates software problems you can check in SP7-403 for information.
Error code 540 will probably indicate some heating trouble in the fix, you have to reset the machine with service code SP5-810.
Code 350 will disappear if you restart the copier.
Oct 12, 2013 | Cars & Trucks
What does the "code" 5E mean on the Audiostrider 990 Pro
Go to Nordic track and find out:
http://www.nordictrack.com/
Jan 20, 2013 | Nordic Track NordicTrack AudioStrider 990...
How to fix error 990???
http://forums.linux-foundation.org/read.php?30,2996 Date: October 31, 2008 02:18PM
ERR (990) ??? I turned it off and back on & still gives me this error code?
Date: January 09, 2009 03:26PM
This is a known manufacturer error. Call Ricoh Direct and talk to someone in Tech Support. If your product is registered with them, they will send you a new printer. You will have to ship the old one back in the same box the new one was shipped to you in, but they provide an RMA # so there isn't any charge.
Jan 11, 2011 | Ricoh Aficio GX3050N All-In-One Printer
Error code 990 still after reset. what to do
Error 990 is an error message that has to do with the ink drying out on the maintenance unit. Unfortunately this is a fatal error and the printer will need to be replaced as the maintenance unit can only be fixed by a technician. You will have contact Ricoh for further information on possible replacement.
Apr 09, 2010 | Ricoh Aficio GX3000 InkJet Printer
Error code 350 error code 990 error code 540
Error code 990 indicates software problems yuo can check in SP7-403 for information.
Error code 540 will proberly indicate some heating trouble in the fix, you have to reset the machine with service code SP5-810.
Oct 09, 2009 | Ricoh Aficio 1035 Copier
I replaced the ink waste tank on my Ricoh GX3000 - then it asked for new yellow ink cartridge and I replaced that. Now I have an error code 990 and I can't get rid of it.
bonjour,
allume ton imprimante,puis retire toutes tes cartouches.
eteint l'imprimante.
rallume l'imprimante et remet les cartouches.
le code d'erreur 990 indique de l'air dans les tuyaux.
ça devrait marcher!
Oct 05, 2009 | Ricoh Aficio GX3000 InkJet Printer
Have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Mar 23, 2009 | Office Equipment & Supplies
Copystar CS-1500 Copier Logo
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
