Don't understand how to connect my speakers
I purchased some used Mission 753f's for use with my Harman Kardon HK 640 receiver but I don't understand the connection on the back of the speakers. Each speaker has 4 inputs (2xLF and 2x HF). Now I understand there's some debate about which plug to use and routing of the cable but I have a bare wire (2 'outputs'). The LF and HF on the back of the Mission speakers have some sort of metal pin that's connecting them. Should I just strip my wire for a few inches and then route it either first through the HF or LF then to the LF or respectively HF? And should I still use the pin? Confused...
  • fixitguy1ca Nov 21, 2013
    the pins are shunts used to allow the speaker to run full range with one amp. they need to be red to red black to black. remove them only to biamp the speakers
  • Martijn Ruijgrok
    Martijn Ruijgrok Nov 21, 2013
    Thanks!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
The 4 inputs are for biamping, (using separate amplifiers for low and high frequencies). just leave the pins in place and connect the amplifier to one red(+) and one black(-) connector on the speaker. It has an internal crossover to protect the tweeter.
Posted on Nov 20, 2013
  • Martijn Ruijgrok
    Just to be clear: Once I decide somehere in the future to use biwiring should I leave the metal pin in place or shoud I take it out as it then seems to have no function, am I correct?
  • Martijn Ruijgrok
    And I also forgot to ask: the metal pin, is it supposed to connect red-red and black-black or red-black and black-red?
4 Suggested Answers
SparkGap
  • 363 Answers
SOURCE: Hooking up speakers to amp
YES ! This is usually ok, the speaker cabinet should contain a high pass filter or crossover on the tweeter to decouple it from the low frequency signals. My Linn Index speakers are wired like this.
Posted on Sep 22, 2007
  • 4234 Answers
SOURCE: New speakers to an old (1960s) record player
It is difficult to say with 100% confidence because the pictures are out of focus, but it looks like you have just a regular turntable. The wire connections you show are the bridge between the tonearm and the external RCA style cables. The extra wire (#5) is the ground wire. You should be able to connect this to any receiver that has a phono input.
For confirmation, can you update this with the model number of the turntable? That will allow me to confirm what I have stated above.
Thanks,
Dan
Posted on Nov 13, 2008
SOURCE: connecting an onkyo m282 to a vintage (1994)onkyo tx905 receiver
I have found the solution.
Using an Audioplex SPKCNV Speaker Level To Line Level Converter should resolve the connection issue.
Posted on Jun 20, 2009
Not getting any sound out of speakers help please :(
You need to set the device on the aux mode. Connect the cable at aux. Sign at the back of the device
good luck
May 07, 2015 | Harmon Kardon Harman Kardon Harman/kardon...
Is it possible to connect a record deck to my Harman Kardon HS500 system
You can connect a turntable to the HK receiver provided the turntaable has a phonograph preamplifier. If not one can be purchased. You can use any line input on the receiver.
Dec 06, 2013 | Harman Kardon HS 500 Theater System
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
Left channel don't work
The IC in it is fied for the left channel.
Oct 29, 2012 | Harman Kardon HK 3370 Receiver
Connecting 4 ohm speakers
I don't think it has anything to do with the impedance. The amp and speakers are well in the allowed limits. The only time this is a problem is if you connect an amp with a greater impedance then the speakers.
This sounds like something to do with the HK 990. It could have a fault on it. You could try listening with headphones if the HK 990 has a socket for them. If they have low sound, there's an electrical fault in the power amp of the HK 990.
Jun 09, 2012 | Harman Kardon Harman HK 990 Amplifier
Hk av500 flashing protect on screen at my house, but not at the shop where I bought it.
What's different? Is it connected to speakers at home but not at the shop? I don't suppose the guy who took your money asked about that.
You may have a shorted speaker/cable. The manual probably offers that as a reason.
Jul 15, 2011 | Harman Kardon AVR 500 Receiver
Just purchased a used hk 3370,only hear a little bit of sound if I turn the volume all the way up.Tried both speaker sets and headphone jack,all the same
Turn the volume down. Maximum volume is not a troubleshooting tool. If it's silent at half volume, it's essentially source-free. No sense blowing your speakers up when we find the setting that's wrong.
http://www.retrevo.com/support/Harman-Kardon-HK3370-Receivers-manual/id/386ag421/t/2/
Let's us FM for the initial silence issue. Tune a station.
Look carefully at the front panel. Analyze every indicator.
Is MUTED turned on?
Is a Tape selected by mistake?
Page 6: items 14 and 15 should be joined by jumpers.
Feb 10, 2011 | Harman Kardon HK 3370 Receiver
Fiber Optic input
No gots. The 3485 is pre-digital stereo-only.
From the manual, page 19
"You may have observed that the HK 3485 is not equipped with digital audio inputs or surround sound decoding. If you prefer the complete home theater experience, you may wish to consider purchasing a fullfeatured Harman Kardon AVR Series audio/video receiver. However, we hope you will find that using a DVD player with the HK 3485 in smaller settings, such as a bedroom or den, surpasses the audio performance of most televisions, including those with onboard stereo speakers."
Apr 13, 2010 | Harman Kardon AVR 240 Receiver
AVR 120 5.1 -dolby surround sound & logic 7.
The problem is fixed...
and every thing sounds great !!
Thanks for the premium assistance to help solve my problem...
Pierre
Dec 07, 2008 | Harman Kardon AVR 120 Receiver
117 people viewed this question
 Grubhead
Grubhead
