Question about Baumatic Ovens
Zanussi oven element
I have a baumatic electric fan oven B205ssa and the element has broken. I have a new on but it has four mounting strips on each end of the element instead of the two from the original (not including the earth). I have attached the wires on one fitting on each side of the element but it is not heating. The element part number is ele6336. Ta
  • 26 Answers
SOURCE: Neff U1721 Double Oven - No Heat
If the fan is running then it is unlikely to be the clock/timer. Yopu need to check if there is voltage to the element but you MUST be careful to avoid an electric shock. There is sometimes a thermal cut out in line with the supply from the thermostat and that would need to be checked. If all OK the thermostat is the likely offender
Posted on Oct 21, 2008
  • 1462 Answers
SOURCE: Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
Posted on Nov 29, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Posted on Jul 23, 2009
SOURCE: baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Posted on Apr 02, 2010
New element still not heating
you need to check the active and neutral connection at the element itself with a meter with the meter connected and correct voltage selection turn the temp up if you have voltage your new element is a dud if you have no voltage check temp controller BUT BE CAREFUL
Nov 21, 2013 | Baumatic Ovens
Fan oven not heating up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
Why is error code F8E0 appearing on my Baumatic B205SS oven and alarm sounding
I have a B205SSA and the error code F8EO is appearing eveytime i have used the oven, i then have to reset it by turning off and back on again at the mains.
Any ideas? Cheers. Rich.
Mar 03, 2010 | Baumatic B205SS Stainless Steel Electric...
Baumatic BT187ss Oven All working EXCEPT fan assisted cooking
I have a similar problem with my Zanussi and discovered there is a seperate element arounfd the fan wihich I think may be burnt out. Could be a similar fault have you investigated behind the panels in side the oven?
Mar 08, 2009 | Baumatic B180 Electric Single Oven
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Jan 17, 2009 | Baumatic B180 Electric Single Oven
Fan oven on zanussi electric cooker does not heat up
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
If fan is working then the element has probably gone
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
No heat in oven
the element may be open circuit, test it by a continuity test. the actual element is inside the metal outer surrounded by a ceramic compound -you will not be able to see any breaks hence the electrical test.
Jun 05, 2007 | Baumatic B180SS And B60SS (Bundle)...
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Ovens Logo
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
