Question about Stanley Bostitch GFN1664K 16Guage Cordless Gas Finish Nailer
Nailer won't work
It won't do nothing
Pin nailer problem
Nice video, you did not mention a model number so I will give you general information. If your nailer is oil free type (gun will have stamped on body, no oil ), and you have been using oil directly or indirectly, most likely rubber diaph. is bad or leaking slightly thru head. Replace headvalve. If your nailer uses orings in the head /headvalve instead of diaph. type firing valve, remove head pull headvalve and apply plenty of white grease or silicone paste and retest. If gun works with grease then most likely needs oring kit and or trigger valve or orings in the trigger. If the gun still will not function correctly with grease in the head, then orings in the trigger are worn. Good luck
May 23, 2013 | Air Tools & Compressors
Senco nailer won't fire nails, but the firing pin dents the wood almost 1/4 inch.
Hi Jes,
Are the nails moving freely in the magazine if you pull the mag spring back? If so, then the driver blade is not returning to top dead centre - leaving enough of the blade to stop the next nail moving into the nose. This could be caused by a slight back pressure in the cylinder so, check the exhaust is clean and free of any swarf. Or check the O Ring on the driver blade, even though you've just replaced them....
Mar 01, 2013 | Senco & Frame Pro 601 Framing Nailer
Nail gun won't discharge a nail
Open the front and see if the nails are feeding through. If the piston is down push it up, close the front and try again.
Nov 21, 2012 | Tools & Hardware - Others
I have a porter cable roofing nailer model # RN175 that does not advance the nails everytime what causes this?
Some causes, in order of probability:
Roofing nailers get a lot of tar build up on them, especially around the nose safety and nail feed pawl area. Cleaning off this buildup will usually take care of most problems with roofing nailers.
On the side of the gun away from the side you load the nails on there is a small cylinder with a piston inside that attaches to the feeder pawl. If air isn't getting to the piston or the piston's o-ring or spring is damaged, it won't cycle properly to advance the nails.
If the driver doesn't retract fully, the next nail won't be able to advance properly for the next shot. This can be caused by o-rings in the head that are worn or out of their proper place.
Oct 06, 2012 | Air Tools & Compressors
My nailer won't work
Do you have a constant air leak at the head of the gun? If so you have a blown diaphram seal. Order from mfg.
Feb 10, 2012 | Shop Fox W1776 18 Gauge 38"2" Brad Nailer...
My framing nail gun won't fire when trigger is squeezed air leaks out but won't fire
Time for oring kit # d518005 available at Dewalt service center or at www.toolpartsdirect.com.
May as well order the replacement trigger valve while there. These two items will renew your gun. Good luck
Sep 16, 2011 | Dewalt Round Head Framing Nailer D51845
Paslode framing nailer fan runs battery charged new fuel .fires a few time than nothing charged batter again couple more shots than nothing?
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Mar 04, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Where can I get a diagram for dc618
Parts and parts diagram available at www.toolpartsdirect.com
I use this company quite a bit for parts. Good luck.
Jul 01, 2010 | Dewalt DC618KA Angled Nailer Kit
Nailer wont recycle
That would be the cylinder check seal on the outside of the cylinder sleeve. That sits in the groove with little holes in it. When The driver goes down the air goes out the little holes and forms a vacuum above the driver, pulling the driver blade assembly back up. So if the cylinder seal is bad it won`t work.
Thanks,
Yooper Jeff
Mar 23, 2009 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Stanley Bostitch GFN1664K 16Guage Cordless Gas Finish Nailer Logo
97 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
