Question about Stanley Bostitch GFN1664K 16Guage Cordless Gas Finish Nailer
Bostitch gfn1664k won'y work
Battery is charger..gas can is inn place and full...grenn light is blinking...bur it won't do nothing
  • 42 Answers
Does fan operate when pushed against the work piece? If not take top of gun (The orange part) off the handle assy. Can you see a piece of white plastic sticking up? if not that is your problem, if it is there connect fan motor and spark plug lead to cylinder head. Connect battery and mind your fingers and cylinder head. push plastic towards rear. Does fan operate? No problem with switch or controller. Yes, keep holding towards rear and squeeze trigger. Was there a spark? No problem with switch or controller. Yes gun working. Problem Gas or seal related. Ensure dosage valve correct and fitted properly, ensure gas in date (Yes it goes out of date and start giving misfires) Check using a good make of gas, some of the cheaper brands are not as reliable. When refitting top part of gun ensure piston is fully at rear and the inside looks clean. Apply thin smear of oil around rim of combustion chamber where it slides over cylinder head. Carry out some test shots. If not firing it is possible there is a sealing problem. With battery removed and gas fitted can you hear gas hiss when pressed against work piece. No you may need to replace the gas cell door. Yes gun may need servicing. (strip and clean).
Posted on Mar 28, 2014
Bostitch GFN1564K cordless nailer brand new wont fire.
take it back to the supplier for a replacement or warranty fix
however as it is electric there may be a safety switch that you have to engage to make it work as it would go off when ever and spray nails and staples every where.
Jun 27, 2015 | Stanley Bostitch Gfn1564k 15-guage...
Nikon Battery into charger, blinks 3 times then no light.
I don't think the charger will blink again when you put back the battery.
The manual says, when the battery is placed and the charge lamp does not glow, the battery is defect.
See the manual:
link to manual
Nov 25, 2013 | Nikon D70s Digital Camera
Conbuston chimber cracked
I think you may be referring to item 79 on this diagram. Either way this shows all the parts with part numbers.
Bostitch GFN1664K diagram
Aug 23, 2012 | Stanley Bostitch GFN1664K 16Guage Cordless...
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
My Black and Decker Firestorm 24 volt charger is not working
change batteries, your charger should indicate wheather you battery is good or noot on the pause inbetween blinks.
Aug 13, 2009 | Black & Decker Black And Decker FS24C...
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Stanley Bostitch GFN1664K 16Guage Cordless Gas Finish Nailer Logo
454 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
