HP has released a patch for AMD based systems. It requires a patch download that must be installed prior to installing the XP SP3 update.
I hope this at least gives you an answer-not one I'm sure you want to hear. good luck
please leave a rating...thankyou
link below
Link to HP patch:
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=pv-60484-1&jumpid=reg_R1002_USEN
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
http://download.cnet.com/%7Bvalue=http://www.download.com/realtek-high-definition-audio/3000-2120_4-75317047.html
Realtek HD audio driver package. The package includes: driver setup program, drivers for Windows Vista / 7 64-bit
hope this helps
