Question about Dryers
NEED TO REPLACE BELT. CANNOT FIGURE HOW TO REMOVE FRONT PANEL ON MAYTAGMDG5806AWW GAS DRYER
OTHER THAN DOOR SCREWS I CANT SEE WHAT HOLDS PANEL ON
    Problem Solver:
  • 14 Answers
You might need to pop the top cover off. Sometimes you just Need to use a spatula or a flat head screwdriver to force it in between the top and the front cover but first make sure there are no Screws holding it from behind. Then you will see what is holding The front cover, removing will see the whole tank And able to replace the belt ? Good luck.
Posted on Nov 21, 2013
    Sergeant:
    Champion:
  • 310 Answers
Pull top and back first
4 Suggested Answers
SOURCE: removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
Posted on Mar 10, 2008
  • 1073 Answers
SOURCE: Replace belt on Whirlpool LE09508KQ1 Electricl Dryer
remove the lint fiter and remove the two phillips screws then lift the top up
you will find two screws on each side of the inside of the frount panel down about 4 inches , this when removed will allow you to swing the frount arround to gain access to the belt
Posted on Apr 30, 2008
mark_37388
  • 100 Answers
SOURCE: I NEED TO REMOVE THE FRONT PANEL OF MY KENMORE 8 SERIES GAS DRYER
One of two ways depending on oh made this unit GE or WPL FIRST look at the top of the door opening for two screws if there is no screws get a flat head screw drive and look with a flash light between the top and front pane you should see a clip about 2 inches from the sides going tworge the middle use a flat screwdriver place in the crack between the top and front panel and hit the back of the screwdriver with you hand should push the clip back an the top pop up do the same onthe other side (before you start if you lent filter goes in the top of the dryer remove the two screws holding that down to remove the front in the side panel going into the front is a screw on both side remove then lift the front up too unclip the bottom clips good luck.
Posted on Mar 30, 2009
How do I get to the motor of this dryer? Do I need to get to it from the front of the dryer or the back?
On a rear control LG, from the front. Open door, remove two phillips screws at 4 and 7 O'clock positions, use putty knife to push in clips (2) holding top at front, swing top back, remove two phillips head screws holding front panel cabinet. Disconnect door switch and light plugs, tilt front panel forward and off bottom tabs, allowing sensor at bottom to be un-plugged, thus front panel now completely free of machine. 4 phillips screws hold front bulk head / front drum roller supports to cabinet. Lift up and off. Reach in and remove belt from tension pulley. Drum comes right out, allowing access to motor.
Jun 13, 2010 | LG DLG3788W Gas Dryer
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
I have a G.E profile dryer dpgt750 cant seem to figure out how to take off the back panel, the dryer is making a loud noise sounds like possible belt problem. any ideals? THANKS MARTY
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Nov 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
I have a kenmore model#110.76662501 gas dryer. I
To access the dryer interior cabinet, follow these steps:
1. Unplug the dryer and turn off gas supply before servicing.
2. Remove the lint screen on the top of the dryer and locate the two screws under it.
3. Remove the two screws and the the top panel will lift up.
4. Disconnect the door switch connector plug and the ground wire (if installed). You may have to use a small flat blade screwdriver to unlock the tabs on the connector.
5. Locate the two mounting screws that hold the front panel to the two side panels. There should be one on each side of the dryer. Place your body against the front panel to keep the door closed and to support as you remove the screws.
6. With the front panel screws removed, grasp the entire front panel in the top center and lift straight up to remove.
You should be able to access the burner assembly now. You shouldn't have to remove the drum, but you can if it will give you better access. To do so, simply release the belt tension by taking the idler pulley and lifting up on the wheel. Remove the belt from the drive motor shaft and leave the belt wrapped around the drum. Using the belt as a handle, you can lift straight up and the entire drum will come out of the dryer.
NOTE: The idler pulley may come detached from the dryer cabinet floor when the belt tension is removed. This is normal.
Remember how the belt goes back in the dryer. If you forget you can re-install the belt and pulley by following these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws. NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you still have questions, please let me know. I hope this helps you.
NOTE: To avoid any confusion, your Kenmore dryer is manufactured by Whirlpool. The "110" prefix in the model number identifies the manufacturer.
Aug 27, 2009 | Dryers
Maytag gas dryer. Belt broken. How do I open and replace it?
On the right front and left front of the panel there are 2 phillips head screws. They are about 4 inches up from the floor. Remove these 2 screws,lift the door panel out then down to dislodge the top clips. Remove the door switch wires and set the door aside. Remove 4 screws from the front drum support. @ on the right,2 on the left. Remove the drum support.Install the belt around the drum. The smooth side of the belt goes against the drum. Re-attach all the parts in front. Remove the belt access panel on the rear of the dryer on the bottom right side facing the dryer to arrange the belt around the motor pulley and tension roller.
Aug 21, 2009 | Maytag Dryers
LG Dryer DLG7188RM LP conversion back to NG
Disconnect power. Open dryer door and remove 2 phillips screws near lint filter. Remove three phillips screws at very back of dryer top which go through an L shaped part into the back of the dryer. (the L shaped part remains attached to the dryer top) Push the dryer top back about 2 inches and lift off. Remove one screw at each top front corner holding front control panel on to dryer. Remove control panel by carefully releasing plastic tabs which are holding front control panel onto metal support. (Watch out for sharp edges !) You can unplug all electrical plugs, or just swing it up on top of the dryer. (careful not to scratch the plastic control panel) Remove the four phillip screws now assessable at the top of the dryer's front panel / door panel. Tilt forward, unplug door switch and drum light, and lift front panel off . Now set the panel aside. At this point, you may be able to continue with the conversion, but it is easier to do and see if you remove the drum.
To remove drum, Unplug the sensor wire at the bottom of the drum support and remove four phillips screws (going into sides of dryer) holding front drum support and lift up and remove front drum support. Reach in under the drum to unhook the belt. Take drum out.
Take two phillip screws out of flame spreader and push flame spreader back off brass orifice into the burner cone a bit to remove it. Unscrew brass orifice and replace with the Natural Gas orifice. Turn the brass slot headed regulator blocker screw on the front top of the gas valve all the way up. Reassemble.
Sounds complicated but it's not real bad.
A FixYa rating is expected with this much help. Thanks.
Nov 20, 2008 | LG DLG5932W Gas Dryer
Dryer Drum belt replacement
first unplug unit..remove front panel 2 screws..under the bottom side of timer console there is 2 pin or scews on each side pull down firmly,or if screws untighen slowly...just let console hang..now you can see the 2 screws holding bottom of front panel door.remove theses 2 screws..now step up on stool remove the 3 screws across the front top of unit,,theses screws are facing the ceiling..now remove door switch connection.remove front ,,you about there if belt has pop remove,if you have to replace a damaged belt..take your right hand and go though machine unit you fell the idler wheel on right side back pull down and take belt of idler wheel and motor pully at the same time ,,if you cant get ittake you left hand and help from the left side..to put back just reverse,,always unplug..
Nov 04, 2008 | Whirlpool LTE5243D Top Load Stacked...
Replace drive belt
there is 2 screws holding on the panel on the bottom of the front, they are on the bottom of the front of the dryer. after this panel is removed, you can see 2 more screws that allow you to remove the main front panel (and the door) then there should be 4 screws to remove the drum support panel, and then you can slide the drum out
Oct 28, 2008 | Dryers
Whirlpool gas dryer model # lgr7646eq3
put back back on with top off remove screws in top corners of front panel remove bottom panel and screws holding blower/lint screen housing on remove door springs remove screws on bottom corners of front belt is probably lying in bottom
Sep 03, 2008 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
