Question about Plumbing
Utilitech sump pump
Not running
  • 3,368 Answers
See if there is power. If so the level switch might be stuck off. If that is OK then the pump motor has probably failed.
Posted on Jun 17, 2014
Motor would not start intermittently. Disassembled to determine possible problem.
The oil has to be there. Intermittent starting is usually the float switch hitting something in the sump. If the pump motor has a capacitor on it, replace the capacitor.
Aug 20, 2015 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Impeller runs, no water comes out. Removed output hose, air is blowing out when removed from sump.
Remove bottom cover, check for clogged intake holes, and make sure the impeller is solidly attached to the shaft. Can you see the water in the sump? Is the sump full of sand at the bottom?
Jun 28, 2015 | Utilitech 1/2-HP Cast-Iron 83 GPM...
Sump pump does not go on all the time have to shake pipe to get it going so water doesn't overflow
There should be a float switch in the pit, sounds like its getting stuck and when you shake it it activates. Check the switch, the rod, etc.
Mar 01, 2015 | Utilitech 0.33-HP Thermoplastic...
We have a utilitech sump pump model #0313508. I am looking for the plastic, or metal standoff through which the float operates.
You might have to make your own. Think of stainless steel rod etc. Utilitech is not a universal brand. Parts are not available and the whole unit is expensive. Grainger does not have anything and it appears that the exclusive provider is lowes.
Sep 20, 2014 | Electrical Supplies
Sump pump will not pump water, won' turn on, floater up
There are a few things that could cause this problem to come up. Pretty much all of them do require taking the sump pump apart a bit though. I would suggest having a professional come to help you if you don't have much experience with this kind of work. Hopefully you can get this resolved fairly quickly.
http://www.rite-waywaterproofing.com/sump_pump_install.php
Apr 30, 2014 | Utilitech Plumbing
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Plumbing Logo
98 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
