Question about HP DESIGNJET 500 InkJet Plotter Printer
Hp 500 error code 0x801003 - HP DESIGNJET 500 InkJet Plotter Printer
Printer hp laserjet 500 color m551 error code 99.06.64 what is the solution to this
are you USB connected, you never said nor what windows you run.
zero inputs, but a code.
I think its kinda new? if you can read , there are many books on this Beast. no lack of them it seems..
https://support.hp.com/us-en/product/hp-laserjet-enterprise-500-color-printer-m551-series/4184772/manuals
it has its own printer web server page, go there yet and look for errors explained, 10x better that codes?
omg I found your pages. its under troubleshooting above
https://support.hp.com/us-en/product/hp-laserjet-enterprise-500-color-printer-m551-series/4184772/troubleshooting
my guess is your post as TYPO>? 99.09.64??????
i say read the last link about and learn to find the true error code
look that up and bingo.
it says HDD failure.
but if 06.99 is real, is it?
the ask at HP.com
HP has business forum, why not use that, on this expensive high end product, or H3ll CALL EM?
hp shows no such code
google non
if not a typo its the first time anyone ever posted for this.
why make sure that code is right and this time get it right.
best for you and x10 better helper chasing phantoms..
Jun 20, 2017 | HP Office Equipment & Supplies
How can I repair laser scanner HP m 500/525 mfp?Every time when it shows the error code,I try to calibrate the scanner and shows black vertical lines.
this is very difficult to solve from your location. I will give you tech support ,please send me your email address or add me your skype xptareq2000@msn.com
Aug 20, 2016 | HP LaserJet Enterprise 500 M525f MFP -...
71:06 error code
hello,
Description:
Out of Memory problem. This Error Code only appears in HP DesignJets 800 Series, or in the HP DesignJet 500 Series with an
HP-GL/2 card installed, when processing either a PostScript or HPGL/2 file.
Corrective Action: Try the following:
Check the amount of RAM in the Printer using the Front Panel
(use the Printer Information utility aPage 4-27). If necessary,install more memory into the Formatter.
If the problem continues, try processing the file in the PC instead of the Printer (select Avoid out of memory in Advanced options in the Driver).
hope this helps
Mar 03, 2015 | HP DESIGNJET 500 InkJet Plotter Printer
Hp designjet 500 with error code 02:10 can firmware be reloaded?
the error code gives :
Carriage failure. The possible cause could be:
The Carriage PCA is not compatible with the rest of the Printer.
The Carriage ASIC has problems initializing.
The +2.5V reference voltage generated in the Carriage PCA is out of range.
One of the Carriage ASIC's cannot be found within the Serial Bus that connects the Electronics Module to the Carriage.
One of the Carriage ASIC's did not respond to the Serial Bus that connects the Electronics Module to the Carriage Assembly.
Go To Below official Hp Printer Page For Your problem, DesignJet 500 error 02 10 Print Head HP Enterprise Business Community
Feb 24, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
Hp design jet 500 error code 5613?
System Error: 56:13
Problem
Description:
Error in the Drive Roller Encoder Sensor quadrature.
Switch the Printer Off and wait a few minutes. Switch the Printer
On again and check if the Error Code has disappeared.
If the Error Code continues, replace the Drive Roller Encoder
sounds like the media motor encoder is dirty or has failed , there are videos on you tube on how to get to the sensor ,OR if your not up to it I would recommend Belmonte Business equipment as being much cheaper than HP to resolve your issue
Nov 29, 2012 | HP Hewlett Packard Designjet 500 42" Wide...
Hp desingjet 500 plus 24"
code error error 21:10 for hp designjet 500 24''
Dec 08, 2010 | HP DESIGNJET 500 InkJet Plotter Printer
HP Designjet 500 System Error 71:06
Check the amount of RAM in the Printer using the Front Panel buttons.
install more memory into the Formatter or
of the Printer (select Avoid out of memory in Advanced options in the driver)
good luck.
Aug 03, 2009 | HP DesignJet 500 InkJet Printer
HP DESIGNJET 500 InkJet Plotter Printer Logo
109 people viewed this question
Seeker5211
Seeker5211
