Question about Maytag Neptune MDE5500AY Electric Dryer
REPLACE THE BELT ON A MAYTAG MDG5806AWW DRYER
CANNOT FIGURE HOW TO REMOVE FRONT PANEL TO ACCESS BELT
    Sergeant:
    Champion:
  • 310 Answers
You dont remove top and back
Posted on Nov 21, 2013
  • 4 Answers
SOURCE: remove front panel of maytag MDG7400Aww gas dryer
You have to remove the front panel first to access the clip that holds the front of the top down. Instructions:
crosstip medium screwdriver
1/4 inch socket
5/15 inch socket
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  4. This has exposed the interior.
Posted on Nov 01, 2008
  • 19 Answers
SOURCE: Need t replace belt on Maytag Ensignia MDE4658AYW dryer
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
Posted on Nov 16, 2008
danromarris
  • 101 Answers
SOURCE: Replace drum baffle on Maytag MDE7500AYW dryer
When you open the door of the dryer you will find screws on each side. First remove the screws that hold the door on, then move to the next side. Once the screws are out you should be able to lift the front panel right off. Let me know if you have any other questions and let me know if this was helpful to you. Good luck and I am glad that I could help.
Posted on Jan 22, 2009
Jahn27
  • 1554 Answers
SOURCE: How to remove top of Maytag dryer
The top panel can be lifted only after the front panel is removed. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
Posted on Apr 28, 2010
  • 3074 Answers
SOURCE: how do i access the
yes it can be accessed from the front panel as it is located on the back right inside of the dryer.
1) unplug dryer
2) open door remove screws
3) with a flat tip screw driver pry gently up on the top corners it will pop
4) move front panel forward and disconnect door switch
5) sit panel aside
6) lift top lid of dryer 90 degrees it has clip/hinged on back
7) look to the right back of dryer, it looks like a spring in a metal box disconnect and replace.
Hope this helps Tim
Posted on Sep 25, 2010
Maytag elec dryer belt broke / how do you open and replace
Remove the 2 screws on the bottom of the front panel to remove the panel and gain access to the drum.
Nov 22, 2012 | Maytag Dryers
Manual on How to replace belt
  • 1
    Remove the power cord from the wall outlet.
  • 2
    Open the dryer door. Remove the screws located along the inside of the doorway with the Phillips screwdriver.
  • 3
    Pull the top part of the front panel away from the MDE5500AY dryer to disconnect it. Lift the front panel up to disconnect it from the metal clips on the dryer cabinet.
  • 4
    Unplug the wire connector leading to the door switch.
  • 5
    Unscrew and remove the four screws connecting the front panel to the rest of the cabinet. Lift the front panel up and away from the dryer to remove it.
  • 6
    Pull the idler pulley toward the left to relieve tension in the belt. Slide the belt off of the idler pulley and the Neptune dryer drum.
  • 7
    Route the new dryer belt around the drum and along the pulley system. Release the idler pulley to restore proper tension in the belt. Rotate the drum to ensure the belt is positioned properly.
  • 8
    Replace the front panel onto the dryer cabinet. Replace the four screws that connect the front panel to the cabinet of the MDE500AY dryer.
  • 9
    Plug the wire connector into the door switch assembly. Lower the front panel down into its original position.
  • 10
    Replace the screws along the inside of the doorway.
Sep 18, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer. Belt broken. How do I open and replace it?
On the right front and left front of the panel there are 2 phillips head screws. They are about 4 inches up from the floor. Remove these 2 screws,lift the door panel out then down to dislodge the top clips. Remove the door switch wires and set the door aside. Remove 4 screws from the front drum support. @ on the right,2 on the left. Remove the drum support.Install the belt around the drum. The smooth side of the belt goes against the drum. Re-attach all the parts in front. Remove the belt access panel on the rear of the dryer on the bottom right side facing the dryer to arrange the belt around the motor pulley and tension roller.
Aug 21, 2009 | Maytag Dryers
How do you take the back off of a Maytag Dryer LDE4914ACE? I want to change the belt?
you cant take back cover off, you remove front cover and then access the top cover then you can replace the belt,there is an access panel on the rear you may need to remove to put belt on motor and idler pulleys
Jul 10, 2009 | Maytag PYE2300AY Electric Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Maytag front load dryer thumps while turning, empty, full etc.
If your Maytag is like my Maytag, there are two screws at the two bottom corners of the front panel. Once you remove both screws the front panel will lift out, up, and off. Then you can see what is going on inside.
Mar 28, 2009 | Maytag Dryers
Maytag neptune dryer making load noise seems unbalanced
Sounds more like the dryer drum seal is deteriorating.
If the dryer tumbles the belt is intact.
To access the belt.
Open the door.
Remove 4 screws on right and left side of the door opening.
Raise the door on the hinge side and remove it.
Pull the front panel forward and remove it.
From there you can see what to do next.
Mar 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
I believe the belt on my maytag electric dryer model LDE412 is going out. How to I get to the belt to remove it for replacement? Through the front of the dryer or the back?
Remove the front panel(s). and you will be able to remove the top panel, which will give you access to the top of the drum and be able to replace the belt. There should be a small pulley at the bottom of the dryer where the belt attaches to, as well as around the entire drum.
Jul 03, 2008 | Maytag Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
85 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
