Question about Health & Beauty
Blinking light on joystick
Chair is fully charged but chair will not go. The speed indicator keeps blinking continues from slow to fast
  • 8 Answers
SOURCE: All the lights are blinking very fast
try pushing the chair. If the chair moves your motors are disengaged. to engage your motors look at the base of the chair there should be a lever possibly 2 push, pull or turn depending and try your chair again if you need additional help you can reach me at 404-966-3734 and i can walk you through it
Posted on Jun 11, 2009
  • 14 Answers
SOURCE: MY CHAIR WILL NOT CHANGE SPEEDS IT IS VERY SLOW
Your batteries are bad or not charged up is it only 1 red light flashing or is it all power lights flashing 1 red means not enough charge. all means internal problem with joy stick
Posted on Mar 07, 2010
  • 7 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair, it is the secondd row of ligths on the controller, the ones that indicate speed. They are flasing steadily
Check that you don't have the charger cord still connected or the motor disengaged.
Posted on Jun 01, 2010
HoverTech
  • 232 Answers
SOURCE: chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
  • 692 Answers
SOURCE: jazzy 1121 power chair won't charge when plug in
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
Posted on Oct 23, 2010
I have a pronto M61. Forward speed is very slow even when adjusted to higher speeds. Turning speed increases normally. Is there a problem in the joystick?
Has this chair got power raiser for seat? if so check it is fully down or check down micro switch. These will not go fast with the seat raised. A safety option built in.
Oct 16, 2014 | Invacare Pronto M61 with SureStep Rehab...
Pride Motor Chair 2008 Vr2 Controller Speed adjustment lights go to fast setting but chair barely crawls along!
Great question! The slow flash is indicative of a speed reduced mode on models designed for a seat lift option. If the controller detects that the seat is elevated then the speed is reduced - regardless of what you try to do at the joystick.
First - try lowering the seat to its lowest position.
If this doesnt work then look for a bad or disconnected sensor switch on the seat post. There are two leads at a 2-pin plug that are not making a connection when the seat is lowered - causing the controller to sense the chair is not safe to drive fast.
Nov 08, 2013 | Health & Beauty
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Aug 21, 2017 | Health & Beauty
Battery level indicator continually flashes when turned on, chair does not move.
Not much info to go on, but you may be in Lock Mode. On a VSI the Profile LEDs scroll left to right.To Unlock a VSI: Push joystick forward until beep, then pull joystick back until beep. Unit is now unlocked.
Mar 09, 2013 | Health & Beauty
Chair is slowing down. Batteries are fully charged.
How old are the batteries? Even fully charged older batteries can be weaker and not give you as much power to keep the speed at what you are used to. Now a dragging bake can cause you to go slower and also drag the batteries down quicker. Try driving the chair and after awhile check each motor to see if they feel overly warm or hot If one or both feel very warm or hot then I would have the brake or brakes checked If they seen ok I would get the batteries replaced
Feb 26, 2011 | Electric Mobility Invacare Pronto M41...
Do not know if chair is taking a charge lights just keep moving across armrest .how do u tell when fully charged?
hi let me see if i can help ,
When the lights go back and forth on your joystick that means the chair knows its pluged in .Now the chair itself has a built in charger that is mounted on the back of your chair .The back of the chair ,there is a opening a cutout in the frame .when you plug in your chair there will be a red light and a yellow ,yellow means the chair is charging, wait till it turns green,this means fully charged.When you plug in the chair youll see the lights through that hole.Look for the lights.
I recommend my customers to leave there chair charging over night look at the light it will be green when you turn the chair on the joystick should show fully charge.
Good luck hope i was of some help.
Jan 20, 2011 | Invacare Supply Group Invacare Pronto M51...
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
Wheel chair won't move. Batteries have been charging for several hours and have some charge but chair will not move.Any suggestions? Thanks
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
Aug 22, 2010 | Pride Mobility Products New Pride Mobility...
How do i get my power chair going after its all fully charged? wat do i press to turn it on get it going?
press the top button on your joystick the lights on the joystick will come on showing battery charge and speed wait about 5 seconds then push the joystick forward and away you go I would suggest placing the spped on slow until you get used to driving the chair
Aug 15, 2010 | Golden Technologies Alante' Power Chair
CHAIR WON'T OPERATE
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Apr 06, 2009 | Pride Health & Beauty
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
