Question about Whirlpool Washing Machines
I have a front load washer a week old and it has started dripping water from the inflow area after cycle is over. It won't stop until water is turned of aat the wall
Water drips from the inflow area after washer ends cycle and doesn't stop unless water is turned off at the wall. Washer is 2weeks old
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You have a stuck solenoid on the water inlet valve.
Posted on Nov 21, 2013
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
SOURCE: water dripping into tub
One of your water solenoid valves are either going bad or stuck open with a little sediment. Find out which is leaking by turning off one of the water lines to the washer. If after it is turned off it still leaks try turning the first water valve back on the turn the other water valve off. This will help you determine which solenoid valve is having the problem. Once identified it is easily replaced.
Posted on Sep 29, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: GE WCVH6260 Front Load Washer
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
Posted on May 31, 2009
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Oct 27, 2014 | Water Heaters
HE3t has an FH error code checked the following and are OK. pressure switch, flow meter, and inlet valves water flows in without restriction. What else could it be? Craig
Thank you for contacting fixya.com.
FH error code means low water inflow. In this error washer is not filling when the fill valve opens.
To clear the error please follow the bellow instructions:-
Press the "Stop" button twice with your finger. This cancels the cycle and stops the washer. Unplug the power cord from the wall outlet.Turn the water shut off valves clockwise to stop the water flow to the washer through the supply hoses. Pull the washer away from the wall enough that you can access the hose connections at the back of the washer.
Set a bucket under the area of the hose connections. Unscrew the hose connections from the back of the washer. If necessary, use a pair of slip joint pliers to help start the connections turning until you can turn them by hand. Set the ends of the hoses inside the bucket.Inspect the screens on the inlet ports on the back of the washer where the hoses connect. Sediment and other debris can block these screens, causing fill problems. Clean the screen with an old toothbrush.
Thread the hoses back onto the washer. Look for kinks in the hoses. Kinks cut off water supply to the washer which causes the FH error code. Once you connect the hoses, turn the water supply valves counter-clockwise to supply water to the washer. Move the bucket away from the washer and push the washer back into its working position.Plug the power cord back into the outlet and start the wash cycle again. If the FH error code comes up again, call a service repairman. If the hoses have no kinks and the inlet screens are clean, there is a problem with either the pressure switch or the flow meter.
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Elite 45986 Front Load Washer: My 2002 Kenmore elite front load washer (stackable...
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 45986 Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Leak on a kenmore washer front load,do not have any trap in front
Apr 05, 2009 | Kenmore 44102 Front Load Washer
Water inflow even after the cycle is complete
Seems to me that you having problem with water valve in this machine. Some solenoid on water valve is stock and water entering the washer even power is off.Water valve Part # 8181694.
Valve located on the top of the washer. Any questions let me know.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
MLE2000 front load washer
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold lines..one screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Oct 26, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Kenmore Elite HE3 Front load..error code F H
**Before you begin make sure to turn off either the hot and cold water valves.**
The resolution is to remove the hot and cold water hoses connected to the back of the washer and remove and clean the microfine filters located inside washer's intake valves.
*The purpose of the filter is to capture all of the mineral deposits from harsh or rusted water particles.*
Basically, unscrew the hoses (connected directly to the back of the washer)
Carefully, remove the filters (they are very sensitive and could puncture easliy)
Clean them off with an old tooth brush in soapy water.
Finally, replace the filter(s), hoses and finally turn on the hot and cold water valves and best of all you will save yourself about $125!
Cheers
Aug 18, 2008 | Kenmore Elite 45986 Front Load Washer
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
